1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2010 sway bar links...looks like me needs new ones
Discussion in 'Gen 3 Prius Main Forum' started by Jeffrimerman, Apr 12, 2021.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Thanks Team Geek. I just jacked up the car on the left and grabbed the tire at 3 and 9 o'clock and tried to force it to turn left or right, not rotate. I also put the jack handle under the tire to pry upward. I did that for both sides of the front. I thought I was hearing just a little bit but the right side didn't make a sound and didn't budge or give but the left side I did hear a little clunk and felt a little give maybe just 2mm or 1mm worth. I imagine on the ground with a ton of weight it magnifies. Seems like not the ball joint since prying upward didn't seem to do anything. It would seem like the tie rod end right? Is there a way to verify tie rod end vs inner tie rod? I'd just change the tie rod end first since inner tie rod would be a bunch of work and if it's not fixed no biggie. Looks like moog has it for $38 on amazon.
  2. Mdv55
    Mdv55 Active Member
    246
    174
    Boston
    Grab the tie rod end and have someone shake the wheel back and forth. You should be able to tell if the movement is there or the inner.
    Team_Geek likes this.
Loading...
