2010 timing chain, can you get it to skip a tooth?
Discussion in 'Gen 3 Prius Technical Discussion' started by ItsDave, Oct 1, 2023.
  1. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    You could buy a tap the size of the plug to clean out the threads.
    Put grease the groove to catch any material.
    When I have a head off, I clean the lower part of the spark plug hole then run
    a plug from the piston side then I know the I won't have a problem with a new plug.
    ItsDave likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,151
    6,308
    Texas Hill Country
    It is unlikely four plug threads are bad much less one. No compression probably means something wrong on the cams, rocket arms or caps. It has happened before.
    I would measure the compression.
    ItsDave likes this.
  3. ItsDave
    ItsDave Junior Member
    29
    Long Island
    I’m leaning towards something to do with the valves too. Was hoping maybe one of those washers came off a spark plug or something. I do not know.
    We’ll know soon because I’m about to dig in to it again
  4. ItsDave
    29
    Long Island
    How does one crank a Prius to do a compression test with a manual gauge?
  5. ItsDave
    29
    Long Island
    Found a thread for that, I’ll link to it later when I have time
  6. ItsDave
    29
    Long Island
    Don’t mind me folks. This is just my new blog as I do this.
    Compression;
    170-170-170-0
  7. ChapmanF
    18,198
    Back in the day, that would be read as a tad bit unbalanced.
    ItsDave likes this.
  8. ItsDave
    29
    Long Island
    Intake rockers for #4 laying in the valley. Timing marks for reference.
    71864279388__63724707-0BDD-45F2-A26C-375E207A54DA.jpeg IMG_3372.jpeg IMG_3374.jpeg IMG_3370.jpeg
  9. ItsDave
    29
    Long Island
    The rockers appear to be undameged. Could collapsed lifters let the rockers fall off?
  10. ChapmanF
    18,198
    Argh. Hmm. Those two intake valves, do they rise up as far as they should now, to seat fully closed?
  11. ItsDave
    29
    Long Island
    No they don’t, by about .100”
    Looks like I bent the valves somehow
  12. ChapmanF
    18,198
    bummer
  13. ItsDave
    29
    Long Island
    Yeah
