2010 Toyota Engine Coolant - Valvoline Brand Alternative to OEM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Purrius, Jul 2, 2023.
  1. Purrius
    Purrius Junior Member
    58
    16
    Northeastern US
    Linked in his description, @NutzAboutBolts uses Genuine 00272 SLLC2 Engine Coolant / Antifreeze from Amazon in his video. Is there a Valvoline brand alternative to this? (I ask because I get a family discount.)
    Speaking of Valvoline, I noticed they use a universal coolant to top of all vehicles at their instant oil change locations. I've never put any in my car, but I'm curious if that could hurt a Prius/other hybrids.
    Thanks, y'all!
  2. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Zerex Asian Red (Phosphate enhanced) I believe.
  3. PriusCamper
    PriusCamper Senior Member
    10,955
    4,441
    Pacific Northwest, USA
    Did you post twice? Here's my reply from your other post: Pink for Asian vehicles is close enough... There's alot of capitalism that furthers problems with radiators from way back when radiators weren't aluminum and plastic and were a high maintenance system. These days as long as its full without air in it and the pumps keep working you don't really need to do anything. Of course I'd love it if the people with antiquated radiator dogma show up to argue this point.
  4. Tombukt2
    Tombukt2 Senior Member
    8,296
    1,441
    Durham NC
    Nothing to discuss in a modern cooling system fill it up with like similar rated liquid and leave it the heck alone Wait for the plastic tank on your radiator to fail or something and get to that. Generally speaking in Toyotas since oh I don't know 75 or 78 cooling systems have been quite the least of the problem you'll ever deal with in any of their cars or the cars I've owned from them other than the plastic radiator tanks cracking at the top right under the neck on older and other Toyotas and I would always replace them with modine's go series metal radiators never had the problem again in my '02 Corolla have a desert cooler which is a 2-in thick radiator core two or three row unheard of in a Toyota this is made generally the light go in the Toyota truck It's the same size as what's in my Corolla I'll post a picture one of these days it's all aluminum I paid $99 for it on eBay brand new.
  5. Mendel Leisk
    38,341
    Owners manual “recommends” Toyota Super Long Life Coolant, but says others may be used if they meet criteria (a lengthy list of esoteric criteria). I didn’t understand half the words in that list, opted for SLLC, but you could research it.
  6. Noahdoge
    Noahdoge Active Member
    165
    119
    Mississippi
    Get the red one. The blue “Asian Vehicle” is for Hondas.
  7. Mendel Leisk
    38,341
    From page 416 of Owner's Manual:
    I looked at the list of requirements, considered I have no clue what most of them are, got the Toyota coolant.
  8. ASRDogman
    ASRDogman Senior Member
    5,941
    3,189
    The cost of "other" coolant, is usually within pennies of the Toyota coolant.
    Why risk screwing up your cooling system, and possible engine with something
    that is close enough?
  9. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Since it doesn’t note non-phosphate it’s likely phosphate enhanced Asian coolant.
    Europeans use silicate enhanced coolant.
  10. Purrius
    58
    16
    Northeastern US
    I'll have to check it again, but it was below the LOW line for at least a few days, but now it's back to FULL? I'm so confused.:(
  11. Grit
    Grit Senior Member
    6,117
    4,041
    Wilkes Land
    Different is cool
  12. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Hopefully not, but something like this may help:
    Block Tester BT-500 Combustion Leak Test Kit - Made in USA https://a.co/d/gewoh1u
  13. Doug McC
    Doug McC Active Member
    989
    372
    Midwest
    2022 Prius
    For information on the why’s of the different types of coolants check out pqia.org (Petroleum Quality Institute of America). They also provide information on whether mixing different types is advisable. It won’t take long to check it out and then you will have the knowledge to avoid following the wrong advice.
  14. Doug McC
    989
    372
    Midwest
    2022 Prius
    From Vavoline’s site concerning the red Asian coolant:
    ZEREX Asian Vehicle contains no silicates, borates, 2-ethylhexanoic acid (2-EHA), amines or nitrites. It is compatible with premium long life Asian vehicle coolants, both for service and factory fill. Valvoline recommends ZEREX Asian Vehicle for all late model Asian vehicles requiring a red or pink HOAT chemistry.
  15. Mendel Leisk
    38,341
    Why am I not surprised lol.
    Doug McC likes this.
  16. Ryan Will
    Ryan Will Member
    63
    37
    Southern California
    I used Zerez Red in my last coolant change, for both engine and inverter coolant. Zero issues, no problems with overheating, etc. But I think the main thing is proper schedule of when to replace fluid.... whichever coolant you decide to go with (Zerex, Toyota, etc.) just make sure to change it at a proper time and don't neglect it.
  17. Purrius
    58
    16
    Northeastern US
    I'll be honest, I'm not entirely sure when mine was last changed. :(
