2010 toyota prius cylinder number 4 indentification
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tjohnson329, Feb 17, 2023.
  1. tjohnson329
    tjohnson329 New Member
    New York
    I
    I have a 2010 toyota prius with a P0304 cylinder 4 missfire. I have read the thread and looking to troubleshoot but I dont know which one is cylinder 4. any help would be appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    12,133
    2,143
    Durham NC
    Stand on the right side of the car with the hood up You're looking straight down at the front of your engine at this point The number one spark plug is the closest to your body number two three and four are right behind so the number for spark plug when you're sitting in the car would be the one closest to your probably right knee so if you're standing in the front of the car It would be the last spark plug on the left closest to the driver the one on the far right closest to the passenger is number one
  3. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Cylinder #1 is closest to the front of the engine. The front of the engine has the harmonic balancer and accessories (water pump, etc). The rear of the engine is connected to the transmission.
    Cylinders are numbered in ascending order starting from the front to the rear.
  4. Mendel Leisk
    40,530
    What's the miles on it? Has the EGR system ever been cleaned?
    Cylinder numbering:
  5. bisco
    51,076
    Same poster with the bad egr
  6. Mendel Leisk
    40,530
    Ah, the ol' double thread trick.
