2010 Toyota Prius model II Head Unit Upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by spiderman, Dec 24, 2009.
  1. miogps
    miogps Junior Member
    PA
    Any alternatives to Kenwood that can also be used as a monitor for Navigation and reverse cam?
  2. miogps
    PA
    much more similar to III NAV (except JBL)
  3. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    Pioneer and JVC also have good units with NAV and reverse camera inputs. Pioneer seems to have the best ipod and iphone integration which is why I chose it.
  4. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Consider me wow'ed
  5. miogps
    PA
    Where can I get more info regarding these units (pioneer/JVC) including reputable online vendors. Thx.
  6. austingreen
    13,675
    4,213
    Austin, TX, USA
    For pioneer
    Pioneer USA - GPS Navigation
    I bought the 110bt and should be getting a $200 rebate
    Pioneer USA - Navi-Days Navigation Rebate
    For JVC
    JVC Mobile Entertainment \ ProductLine Navigation
    I bought through a pioneer authorized reseller through amazon (they were cheaper there than on their own site). You need to go authorized to get the rebate. Amazon also has the JVCs and kenwoods with some user reviews. You can search the forums to see opinions on the units.
  7. xxxx ne0 xxxx
    xxxx ne0 xxxx Junior Member
    Las Vegas
    I wonder if best buy stereo installers can do this kind of install, since it looks like a lot of work? nice job, looks better than the OEM.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh I am sure for a price just about any shop will do it. Granted I have done a few installs before, but it really wasn't that hard. A person could try and if they just couldn't finish it, they could then bring it in.
    Not only does it look better but the sound is soooo much better!
  9. Runciter
    Runciter Junior Member
    Commonwealth of VA
    Nice job, excellent write up :)
    How well does the SWI volume controls work? Any delay?
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My PAC works wonderfully, no delay. Since I have a model II, I only have Mode, Vol (up,down), Channel (up,down). I was quite relieved that this was the case as there was talk on the web about possible delay.
  11. Runciter
    Commonwealth of VA
    Good to know. Was thinking of adding that SWI to my other Toyota (non hybrid). I too was worried about the delay.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I have SWI-JACK with a Kenwood head unit. There is some delay. The buttons SWI-JACK use are not instant like OEM. I have to hold a fraction of a second longer. I don't know if that delay is from Kenwood or SWI.
  13. Rainingblood
    Rainingblood Junior Member
    35
    Italy
    Help me please!
    I have a Alpine 114BTi (parrot bluetooth & ipod full speed cable)
    the first pic is the Metra 70-1761 wiring harness
    and the last pic is the alpine wiring harness
    speakers cables is ok
    · green (left rear positive LR+)
    · green-black (left rear negative LR-)
    · white (left front positive LF+)
    · white-black (left front negative LF-)
    · grey (right front positive RF+)
    · grey-black (right front negative RF-)
    · violet (right rear positive RR+)
    · violet-black (right rear negative RR-)
    from the metra kit to the alpine ISO connector i think the is no problem...
    but the other wires???
    · orange (dimmer) DIMMER (i must connect to the iso plug or spare wire?)
    · yellow (battery constant 12v +) (i must connect to the iso plug or spare wire?)
    · red (ignition/switched 12v +) (i must connect to the iso plug or spare wire?)
    · black (chassis ground 12v -) (connect to iso plug)
    · blue (power antenna) (connect to iso plug)
    ALPINE MANUAL http://www.alpine-electronics.co.uk...audio_manuals/CDE-114BTi/OM_CDE-114BTi_EN.pdf
    somebody can help me?
    Thanks
  14. xxxx ne0 xxxx
    Las Vegas
    What is the best hu that has all the high end features of a car stereo, and GPS with all the latest maps and lane assist? suggestions?
  15. briprius
    briprius New Member
    Ontario
    Does the touch tracer display still work when the SWI is used with the upgrade?
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes.
  17. Ananda
    Ananda Junior Member
    tacoma, wa
    I just finished my HU upgrade. I have a base model II and put in a JVC NT3HDT with SWI-JACK. I did install the bluetooth mic but not a back up camera. My expectations are very low for the bluetooth, as I have jawbone that sounds really good, and was tempted to just omit the bluetooth mic.
    I'll post pics later. My impressions:
    1) the process was much more difficult that anticipated. A number of posts here talk about how easy it is so perhaps my expectations were set poorly. After tracking down all appropriate parts, figuring out the wiring, and soldering all the wire connections except those from the SWI wires to the 20 pin car harness wires (which must done with HU out), it still took me 5 hours from take apart to put back together. Total time spent must've exceeded 10 hours.
    2) Most of the difficulty was in getting the HU to fit right. I had to grind and drill the brackets and the HU fit is still not perfect but as good as I'm going to get it. The HU just has gaps between the plastic surround.
    3) The SWI-JACK works but has a roughly 1 second delay.
    4) FM reception is still poor. The HD FM radio fades in and out and has an echo. I need to look into bypassing HD FM I guess. A bit disapointing.
    5) The sound improvement is minimal to moderate. The improvement is not as significant as I was expecting. Perhaps I need new speakers and an amp. The new HU just doesn't seem to deliver a strong sound.
  18. Ananda
    tacoma, wa
    Attached is a pic of my install.
    The JVC won't allow some operations like entering an address in NAV while the car is moving. Of course, this is an unadvertisted "feature". If you ground the parking brake line, all features operate whether the car is moving or not.
  19. epete
    epete Member
    76
    27
    New Jersey
    Just picked up my 2010 Prius II today. Now looking into how to update the radio. The attached document in to OP is great. I am a little confused and was hoping someone could clear up my confusion.
    Does all this text apply to part #1 in the picture?
    [FONT=CenturyGothic,Italic][FONT=CenturyGothic,Italic]
    No tool needed. Just use your fingers and nails. Just pull with enough force. Don't pull
    slowly, just yank with enough force but make sure you only pull with about 1-3" of flex.
    Don't pull it so hard that your whole body jerks. Just use your forearms and flex only
    between the elbow and hands. They are all held by plastic clips that are sturdy so don't
    worry about breaking the clips.
    Where do you start? At the bottom, near the cup holder? Does teh entire piece all the way up to the top right come off? It would be nice to know approximately where the clips are and how many there are.
    I guess what is confusing me is that there are four parts labeled. The first part is described followed by a paragraph befinning with First, another with Second, than third and fourth. I may sound picky but when ripping into a new purchase, I want to be sure I am doing the right thing.
    First, I recommend by removing the black surround that's at the base for the shifter. Lift it
    out of the way and rotate it to the driver side (or you can unplug it and remove it​
    entirely.
    [/FONT][/FONT]Again, I wish there were additional descriptions other than "lift it out of the way" Am I to assume this part (labeled 2) is held down by part 1 so that once part 1 is removed part 2 simply lifts off? No fasteners?
    Second, start pulling off at the base where the cup holder is and start tugging upwards
    towards the upper corner leading up from the heater controls upwards towards the​
    right side of the stereo.
    [/FONT][/FONT]OK, I thought I already removed the part labeled 1 with the cup holder. Did I misread the first paragraph? Or am I misreading this one?
    Third, carefully start pulling off the plastic surrounding the radio. Don't yank all the
    corners at once. Again start at one side and work across to the opposite side.
    How is the plastic sourounding the radio held in place? Again, with clips? Are we talking about theh part labeled 3? You went through the trouble labeling the parts and therefore you should refer to them by your label. Or maybe you did if the third step refers to the part labeled 3.
    Fourth, remove the "Power" button cover. In the same way, just tug and it will snap out​
    of its slot.
    [/FONT][/FONT]Now I am wondering how the Trim gets re-attached. I would love to see pictures of the back of the trim in it's removed state.
    The rest of the guide is clear enough and some may be specific to the HU that was selected.
    I am wondering if theer are any other sources out there that I can use to fill in the gaps. Wondering if the materials from Crutchfield will be sufficient.
    Again, thanks for all of the work. Maybe some additional comments explaining some of my questions will make this resource better.
    [/FONT]
    [/FONT]
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thank you. It is hard to write up stuff in detail when after you do it and find out how easy it is. I was really worried myself the first time but now I can take it all apart in about 2 min.
    So start with the cup holder. Grab inside and around the outside edge to where the seam is. Give a good yank up. Once you see how it is held together it all makes sense.
    If you still have problems, I will make a quick video.
    Good luck...
    Peter
