2010 Toyota Prius model II Head Unit Upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by spiderman, Dec 24, 2009.
  1. stugomer
    stugomer New Member
    Los Angeles
    Nice work - question
    thinking about a pioneer x930 or 130 not sure - how did you deal with the mounting kits as the two i looked at dont match the prius grained look dash - they are smooth.. any insight would help
    thanks
    stu
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard Stu, thank you.
    The surround as mentioned in the document does match perfectly as it is an OEM part. The problem with is it is that you need some filler pieces to work with double-din sized equipment. I guess that is the trade-off at this point.
    Good luck.
  3. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I have a dilemma - I have free Sat XM radio - so if I change my head unit I'll "lose" it. Snif.
    Over a year now.
  4. prius2010II
    prius2010II Member
    269
    23
    us
    I attached the install instructions for the Myron&Davis Prius specific HU. Looks like it's the same as the Coagent/Flyaudio etc. Nothing new but sometimes one report is easier for some people to follow.
    2 people like this.
  5. k9frog
    k9frog New Member
    88
    sullivan co ny
    thank you much for the info,i also found out that if i go to there store in canada, itll cost me 150.00 for the install, i think with all the info here in the forum i should be able to install with out any problems,, mike
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Added another document inspired by TJ Minski (big thanks)... it covers upgrading the rear door speakers.
    The upgrade really helped adding the high frequencies to the rear area but admittedly I seemed to have lost some low end bass volume. For me that isn't a big deal as I have a sub to compensate. Overall the sound quality was improved. :cool:
    Enjoy
  7. spilknight
    spilknight New Member
    First Post here on the forums, only had the Prius for about 1 month, 2011 II. Anywho, the guide attached on the initial post, I was looking for something like this although I'm not planning on upgrading the head unit just yet, but rather I am going to install a Sirius receiver so I can use the pre-wired antenna and the factory head unit instead of a the ol' button antenna and mounted tuner. The process (up until actually changing the HU) is identical I would think. And I was hoping someone that has installed a new HU might be able to confirm if there is in fact enough space behind the factory HU to mount the Sirius Directed Receiver (TOYSIR2) as I have seen mentioned,suggested in other posts/threads.
    I can't seem to find one good thread about installing a Sirius Receiver that describes in detail the process such as in this HU upgrade. I'm all for documenting my install, and maybe that's a topic for another post at another time, but before I start taking trim pieces off, I was just looking for a little confirmation.
    This will be first mod on the Prius, first for any car of mine too. So yeah, I'm in the gather information stage so I don't f-up my new ride and end up spending more to fix my mistake kind of mode. Any help would be greatly appreciated. And if anyone knows of a good thread dedicated to installing the TOYSC2 please point me in the right direction. Yes, I have used the search; Yes, I have spent time looking for other posts on this topic, No, I'm not a noob to ignorant to first search in their own for the answers to the questions I have asked.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I am not familiar with that receiver but there is a lot of room in that dash.
    The nature of these mods is a walk into the unknown. That is why these types of threads/posts are so valuable. You can probably have the HU out in 10 mins. :)
  9. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thank you. Wow, what an equipment list... must sound awesome! Great job.
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I finally started the rear camera install today. Holy smokes, it's a bear of a job! I have all of the rear trim out and sitting in my garage, and I have the video cable run through the rubber boot, and snaked to the license area. I partly put things back together and I'll drive like this until next weekend, when I'll get more done or finish it. I definitely feel like I have the hardest part done, the only part I'm not sure of is how I'll run power. I'd rather not snake another cable through that rubber boot, especially since I finally got the thing reassembled.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, after getting that power wire to the camera you will have the hardest part done. :) That boot was a pain... lost some skin on that one but managed to get all the wires I need through it. I ran the RCA through with some twine attached and then attached the other wire to the twine and pulled that through.
  13. Rebound
    3,996
    2,644
    Portland, OR
    Where do you run camera power to? Is there no ignition-switched 12V power source already available in the hatch?
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I ran it all the way forward to the HU yellow wire. The trigger wire I ran all the way forward from the left reverse light. Someone found a reverse wire at the driver's foot panel but can't remember the details.
    Wums likes this.
  15. MrPete
    MrPete Active Member
    500
    190
    Colorado, USA
    FWIW: I found it relatively (!) straightforward to get wires through the boot by using a piece of heavy string trimmer plastic wire first, then taping my wires to that, coating with WD40, and pulling it through.
    StevenM and spiderman like this.
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ did you get the steering wheel controls working the way you wanted?
  17. skylarii
    skylarii New Member
    34
    OR
    I just noticed that you installed what looks like the Toyota bezel onto the Metra adapter? How did you manage to make it fit? I am having a problem trying to use the Toyota trim with the original radio mounting hardware. My Pioneer 3200bt sits too far down into the dash. Did you make some mods to do this and how did you manage it?
    Spiderman, looks like you are the the father of the Pioneer ranks and I am grateful for that. As I noted above, I am not having luck with the fit of my avh-3200bt in the dash replacing the stock basic radio. Using all the mounting hardware from the radio plus the spacers used with the Toyota trim just won't fit properly since it all sits too far down into the mounting space. I have both Metra and Toyota trim and adapters but was hoping to get what I have to fit since I like the look of the Toyota piece better. I see the full writeup of ALEMAN and see that he did a nice job with making the necessary mods to the original pieces which I followed but none of it addresses the depth issue. Any thoughts or suggestions to make this work would be great, I can always go with the Metra kit but that is my last resort. The install is in a gen III PII btw
    Thank you!
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ all of us that used the OEM brackets had to grind them out to work. The instructions (mine at least) include that information.
    My pleasure, love to help.
  19. skylarii
    skylarii New Member
    34
    OR
    That is great and most appreciated. So I still did not see how you got the HU moved up far enough to seat well into the Toyota bezel? Did you use spacers or somehow move the bracket further down (different set of holes)? I see the oversize drill holes but that was all that was needed? Any thoughts would be a bonus as I am at a stand still.
    Thank you
  20. Rebound
    3,996
    2,644
    Portland, OR
    I bought the Metra bezel, and I used the bracket that came with the Metra bezel with the Toyota faceplate. This made spacing quite simple. I also ran a strip of Velcro "fur" along the top edge of the unit for a snug fit without light leaks.
    StevenM likes this.
