2010 Toyota Prius PHV Prototype Full Test and Video
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Yossarian, Jun 24, 2010.
  1. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Easy.
    Do you have another car? If no, don't buy the leaf.
    Do you want to save as much money as possible? If yes, keep your current car.
    Do you wish to raise awareness of EV's, reduce your petrol use further, and make 99% of the people on this forum jealous? Buy the PHEV!
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    You should limit your replies to only those facts you know.
    Perhaps you are not aware that some of us here have already test driven the PHV. I think those of us who were there know the difference between EV and ICE.
  3. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    I could use some clarification on the use of the larger "battery"
    -- as I understand it there are actually three separate batteries
    masquerading as one. If I understand it correctly, as the PHEV is
    presented in the Edmunds piece, at the beginning of the day/drive it is
    run in pure EV for ~14 miles until the PHEV portion of the battery bank
    is effectively depleted and then run as a non-PHEV, regular Prius.
    Is this the only way to operate the car?
    At the beginning of the day, could you chose not to go into EV, and
    then use the additional electrical power at your discretion for on-and-
    off EV power through out the day/drive.
    I'm thinking about long drives, maybe 100 miles or so, perhaps most
    at highway speeds. I would expect that just how you would maximize
    your FE/MPG would be highly dependent on terrain, weather, speed,
    etc... the usual YMMV suspects. :rolleyes:
  4. Flaninacupboard
    1,297
    213
    Midlands - UK
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's correct. Having a button would actually disqualify it from certain certifications.
    Think of the PHV as an Iconic Prius that's highly caffeinated. :D
    Stealth is a whole lot faster and more powerful, but there is no option choose that mode. If you drive within the tolerances, it automatically engages. If you exceed those tolerances, you get to drive with an engine that's assisted by the motor much more than it normally would.
    So, there's a boost to efficiency regardless of how & where you drive.
  6. Flaninacupboard
    1,297
    213
    Midlands - UK
    Ah, so in europe we'll probably get the button. nice. as mentioned there would be situations (such as a trip to then through a large city) when holding back the EV mode would be desirable.
  7. john1701a
    12,840
    5,312
    58
    No, quite the opposite.
    To qualify as free or discounted rates in emission-reduction zones, you'd need to have a system that does it's best to make the feature automatic. In other words, no button... since it could act as an override.
  8. Tideland Prius
    16,678
    Yes. They are called Main, Subpack 1 and Subpack 2. The subpacks are for PHEV mode and the Main pack is for HV mode. The car defaults to PHV so anytime you're in HV and you lift off, you're back into PHEV mode.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm glad to see that people like John are 'getting it.' If the car is good for x EV miles in a certain driver's hands, it just does not matter if the car went x miles or 3x miles before the next charge. X miles of EV were driven. We used to call this 'blended' driving.
