2010 traction control
Discussion in 'Gen 3 Prius Main Forum' started by was, Jun 16, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    No defeat switch. Yet another example of dealer misinformation.
    Tom
  2. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Dear was,
    I just got a bit of extra info on that subject! Thanks to zenMachine who gave us the link (http://priuschat.com/forums/gen-iii...anything-you-want-about-prius.html#post915302), I asked your question on that forum and got an answer! (see You ask, they answer: Japanese car firm Toyota | Environment | guardian.co.uk)
    Here is their answer:
    Would any experienced Prius II driver tell us what that would mean in terms of driving experience on slippery conditions?
    2 people like this.
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    To translate:
    Toyota finally implemented the kind of traction control system that has been around for quite a while in other makes and models of car. (Decades.) If a wheel loses traction you will hear the ABS kick in on the one wheel...a grinding or buzzing sound. That gets power transferred back to the other wheel in hopes that it will have more grip. With any luck this will reduce the tendency for the car to bog down and give people the sensation that it quit. It has worked well in other FWD cars that I have driven with this kind of system.
  4. was
    was New Member
    16
    Boston
    Thanks, CivicQc! That would seem to confirm the earlier report about a qualitatively improved TRAC that will for the first time allow the car to move if only one front wheel has traction. It will be interesting to hear how new owners do this coming winter. My guess is that this improvement will bring the Prius to approximately the same level of low-traction performance as other front wheel drive vehicles with good traction control that can brake an individual spinning wheel. The Prius may still be hobbled to some degree by the inability to spin its drive wheels as much as some other cars to try to dig out of snow, mud, etc. I don't think we'll know until a winter of real world experience has arrived.
    Thanks again.
  5. lowcarbzone
    lowcarbzone New Member
    Reston, VA
    Is there any proposed solution for the 2006 Prius model? (Gen2?) I posted the problem a couple of years ago when it happened on snow, even with snow chains on the front wheels. Then I had the same problem in summer on a gravel driveway with some grade to it. I can replicate the problem there any time. My Prius is arguably unsafe in snow as a result. By the way, I grew up in snow country and have plenty of experience of driving a wide range of vehicles on snow and ice and can assure you it is not "pilot error" as some posters have previously replied. Is there some way to get around this problem other than replacing the car? I am told that the problem is not encountered on all 2006 models, just some.
  6. marcinpisz
    marcinpisz New Member
    45
    Edmonton, Alberta, Canada
    Traction control is particularly important in areas like Canada where the winters are long and cold. A traction control systems are totally loses all power is not just a flaw with the second-generation Prius and has been known to happen in early 90s General Motors vehicles. The problem gets particularly bad, if the tire tread is worn out giving the tires less grip. Having a system that totally gives up, is almost a dangerous thing. Ironically I have been in the second-generation where the parking brake was left on while the driver attempted to move on the slippery surface. At least in the 2009 model, the system appeared to have jerked the car around like the wheelspin was being transferred from one side to the other. This leads me to believe, that the generation to system is probably very similar to the generation three system with tuning adjustments. Being that it was very slippery there, I definitely did not do the system give up. It was like going through slow motion antilock brake system vibration but only accelerating instead of trying to slow down. I think where the really big benefit is that the new third-generation is in the vehicle stability control system being standard on all models. One thing I would recommend is a set of studded winter tires if they are legal in your area. Newer studded tires have soft padding so they don't damage the road like the old ones did but still offer the ultimate in traction. I think when I get the generation three I will get it with a 17 inch wheels because I like the other features that model in Canada comes with. But for the winter, I plan to get myself 15 inch set of rims and some Nokian factory pre-studded tires. The narrower rims are going to be an advantage on the snow. I work shift work, so I leave for work at 4:30 AM usually before the snow plows had a good chance to remove the snow from the road. Using a small front wheel drive car I have never been in a situation where I cannot make it work. And I have seem some deep snow. If anything that can slow me down, is a large wind drifts of snow since my ground clearance is not very good. From what I've heard, the second and third generation post to not have very good ground clearance to maintain good aerodynamics.
  7. Tideland Prius
    16,634
    wow that was hard to read. A few paragraphs would help =).
    Stability Control wasn't standard but it was optional on the Gen 2. I will say that the Gen 3's traction control has been improved and I have video to show that.
  8. qbee42
    18,058
    3,081
    Northern Michigan
    I gave up halfway through. Did I miss anything?
    Tom
  9. Tideland Prius
    16,634
    Whatever I answered was what I got out of it.
  10. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
  11. nspeer
    nspeer New Member
    17
    Colorado
  12. Tideland Prius
    16,634
    You're comparing an AWD car to a FWD car. But then again I think a Camry *might* be able to get up with the same tyres.
    The Gen 3 is much improved (i.e. it's the same TRAC as other Toyota models). You can see my video done with Nokian Hakkapeliita R winter tyres on a road covered with a thin layer of ice on youtube (or search Tested TRAC, VSC tonight)
  13. aapoppa
    142
    NC Mountains
    I totally agree with you but most other Priuschat people won't. I'm waiting for our first bad weather and can only hope the Gen III will be better than my old Gen II was.
  14. fuzzy1
    10,630
    Too bad you couldn't keep the Subaru and use the Prius as a replacement for something else, as I did.
    My Subaru certainly can get stuck. Not being an Outback, it gets high centered several inches before yours. But there are times when I want a rig that doesn't get stopped by that man with a gun, standing in the middle of the road next to a Chain Checkpoint sign.
  15. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    same here.
    i came from 5 subarus over 12 years.
    i could always depend on them.
    the prius abs system, in the wet, sucks.
    i just hope we have very mild winter here in NJ.
  16. CivicQc
    233
    99
    Planet Carbon
    Ok, now that a significant portion of winter is behind us, would the PriusIII owners who drive regularly on snow and ice confirm that the traction problem that used to caracterize the PriusII is now a thing of the past?
    In other words, is the Prius III capable of climbing snowy hills as efficiently as any other front-wheel drive car? (assuming they use the same tires)
    (It may sound strange, but we have had only a little snow this winter, and it nearly always fell during the weekends, so I could never test drive a Prius in snowing conditions).
    (It may sound strange to many of you, but dealers are closed during weekends over here...) :(
  17. Tideland Prius
    16,634
    I think it's a better winter vehicle than the old one. My old one has the updated slip 'n grip TCS after the ECU was replaced. It used to the be slip and kill power type. So far, no one's figured out how my TRAC managed to change behaviour. Nonetheless, the 3G is better and acts like a normal Toyota TRAC.
  18. LeadingEdgeBoomer
    289
    29
    New Mexico
    We live on a private, unpaved street, and my driveway is uphill from the paved street leading to it. Until we get our street significantly fixed this summer, it turns into a mud bog as snow melts. A few days ago, on melting snow over mud, I decided to drive very slowly to minimize additional road damage. Traction control came on, and I had great difficulty finding a path that would get me to the driveway (nicely paved, shoveled and dry).
    I learned to keep the speed up a little (not even to the normal level), and it goes fine.
  19. aapoppa
    142
    NC Mountains
    I was a loud detractor of the TC on my '05, going as far as to say that the car was dangerous to drive on ANY slick surface.
    After driving my Gen III for 15,000 miles and through one of the worst winters ever in my area, I can categorically say that the car does very well on snow, ice, and mud.
    A world of difference from my Gen II!
    2 people like this.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I didn't own a previous Prius but I can say that my 2010 does better than my 97 Camry in everyway. I thought my Camry did pretty well too.
