2010 transaxle fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WeidnerL, Nov 21, 2013.
  1. Mendel Leisk
    42,148
    Here's an excerpt from the Repair Manual.
    Paul R. Haller likes this.
  2. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    I paid 89+tax in Chicago il area. 46,xxx on the clock and had them capture some fluid in a water bottle container and it was pretty funky and dirty. Service manager was surprised at the condition as he had just told me an hour before it was 'lifetime fluid.' ;) I told him, 'I'm happy I had it changed.' It's a drain and fill and they looked at me like a fool for spending my money to change it.
    Turn off signatures in Tapatalk Tapatalk
  3. TheredBull
    TheredBull Junior Member
    30
    Southern California
    I changed my transmission fluid on my 2011 with 34k. The used fluid looked brand new. Did you see them changing it? :)
  4. elementnomore
    136
    44
    Los Angeles
    I have changed a gen 2 with 67,000 and it looked black. I've seen the new stuff and mine was a dirty grey pink color. I asked the tech to save some fluid. It seems like a huge professional operation and at some point I have to trust that it was my fluid. I would have rather changed it myself and spent less money oh well.
  5. Mendel Leisk
    42,148
    $89's a very reasonable charge. The 4 qts/liters and 2 washers retail for around $40.
    OTOH, if you have the garage and rudimentary equipment, it's an easy maintenance, not much different than an oil change. Last time around I did both together.
    elementnomore likes this.
  6. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Just did mine. 160k. Pitch black. $9.45/qt. no questions from dealer. Picked up pump at HF. 5$ and change. Didnt use new washers, look just like flat washers vs crush type! Put in 3.5 qt.
    Lifted in shop. Easier than changing oil! Less time too! Torqued to 29.
    New fluid smelled like something You could drink, old fluid smelled really bad! No metal or signs of wear. Just old wore out fluid...I can rest easy now!
    Going to monitor noise level,MPG, and interaction of ICE/transaxle!
  7. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    But don't :eek:
