2010 Turned off while driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 23, 2023.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Good thing I was not on the Freeway
    Car turned off while driving won't turn back on
    Big Yellow triangle check engine symbol too
    Check Hybrid System on dash monitor
    91k miles
    Here are the Codes given (Giving as much detail as I can)
    This one is prominent First thing that shows up (stored) Global OBD2 U0100 " Lost commucation with ECU/PCM "A"
    If drivability issues are present Threat to essential system components if not repaired ASAP"
    Under Hybrid Control module Codes given
    P0A0D
    U0100 (shows up again)
    Under ABS/VSC/TRAC module Codes Given
    1253
    1256
    1259
    What is wrong ? THANKS
    #1 Taxi/Limo, Jul 23, 2023
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    Did it restart? Brakes ok?
    Was PO80D actually a POA0D ?
    The other codes could be a side effect of the hybrid system quitting or a brake booster fail.
  3. Taxi/Limo
    526
    107
    It will not restart I get "check hybrid system" on the main dash display
    The brakes seem okay
    Yes P0A0D (I corrected my original post)
    #3 Taxi/Limo, Jul 23, 2023
  4. rjparker
    11,096
    6,962
    Texas Hill Country
    Messing with the hv battery orange plug?
  5. Taxi/Limo
    526
    107
    I disconnected and reconected it to see if that was the problem. (It was not this time)
  6. Taxi/Limo
    526
    107
    I am a bit surprised only one person responded
    Problem “fixed”
    Cleared codes turn off and on again
    Car started up
    Ran system check again
    DTCs Only two
    ABS/VSC/TRAC
    1253 pump motor relay
    1256 Accumulator Low pressure
    No codes for Hybrid Control anymore
    What happened and What do the remaining codes have to do with anything?
    Thanks
  7. rjparker
    11,096
    6,962
    Texas Hill Country
    After verifying the orange disconnect, you have to clear the code next. So it could have been the issue. Still may have a brake booster issue.
  8. Taxi/Limo
    526
    107
    Yes Thanks
    Question
    What would cause the code U0100 to come up the orange breaker disconnect or something with the ABS?
    #8 Taxi/Limo, Jul 24, 2023
