2010 Two Front Hub Bearing Swaps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, Mar 4, 2022.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    OVERALL. Nice project today swapping out both front hub bearings in 5hrs. I'm fortunate today to have access to a shop lift & pneumatic tools. Passenger side front hub bearing was bad by making grinding noises at 246k miles. Rationale to swap out both-- with cheap parts & that i was already under the vehicle, I normally swap both symmetrical side parts out in tandem. I didn't affect any of the steering, so a wheel alignment was not necessary.
    1. LIFT & REMOVE TIRE. I lifted the car, removed both the front wheels and their axle nuts (with penetrating oil). I had to use a pin punch to bend out the dent in the axle nut. With a dead blow hammer I hit/pushed the axle inward to evidence free play away from the bearing-hub & knuckle.
    2. FREE-UP KNUCKLE. I removed two hub bolts connecting the driver front strut & upper knuckle. I removed the 3 bolts connecting the lower ball joint, leaving the ball joint still connected to the knuckle. I removed the castle nut attached to the tie rod end. Also disentangled the ABS nub & brake lines attached to the knuckle.
    3. REMOVE OLD HUB BEARING. Now with the knuckle free, access is now available to the inside where the hub bearing is located. Remove 4 bolts. Press out or hammer & punch out the bearing.
    4. CLEAN KNUCKLE & DUST SHIELD. In the deep sink, I thoroughly wire brush cleaned these.
    5. REPLACE NEW HUB BEARING. I lubed the new hub bearing lip with white lithium lubricant to avert future rust & promote ease of future removal. Reinsert 4 bolts; star pattern them back in.
    6. RESEAT KNUCKLE. In reverse, I replaced the two hub bolts, 3 lower ball joint bolts & ABS & brake lines connecting front strut & upper knuckle- torque specs- strut bolts 177ft lbs; axle nut 159ft lbs; hub bearing bolts 30ft lbs.
    7. REPLACE TIRE. Since I was already under the car, I rotated the tires back to front. Torque lugs 77ft lbs.
    8. REPEAT OTHER SIDE. Now for doing the same procedure for the driver-side front hub bearing.
    9. ROAD TEST. a few days post procedure, all things fine: no alignment problems, no weird wheel noises, etc.
    TOOLS.
    30 mm socket
    12-22mm assorted deep sockets wrenches
    breaker bar
    mallet; dead blow hammer
    pin punch
    punch
    torque wrench
    spray brake cleaning
    white lithium grease
    spray rust penetrant
    20220303_144930.jpg 20220303_144934.jpg 20220303_144949.jpg 20220303_145003.jpg 20220303_145037.jpg 20220303_150256.jpg 20220303_150307.jpg 20220303_153012.jpg 20220303_153621.jpg 20220303_153630.jpg 20220303_160250.jpg 20220303_160253.jpg 20220303_160257.jpg 20220303_160617.jpg 20220303_160631.jpg 20220303_161140.jpg 20220303_161142.jpg 20220303_161349.jpg 20220303_161354.jpg 20220303_161804.jpg 20220303_164036.jpg 20220303_164039.jpg 20220303_170720.jpg 20220303_174812.jpg 20220303_174816.jpg 20220303_174818.jpg 20220303_174820.jpg 20220303_174822.jpg 20220303_174826.jpg 20220303_174828.jpg 20220303_183256.jpg
    52,808
    great write up and pics, thank you!
    Prius_Angie likes this.
  3. ChapmanF
    18,995
    Do you have equipment to test the alignment, or are you saying "no alignment problems" because you didn't notice any issues driving the car?
    Those bolts holding the knuckle to the strut are used in the camber adjustment, so that should be actively checked after they've been disturbed.
    What some people have done is go to a Firestone shop and buy their "lifetime" alignment service once; that lets you go back and have alignment rechecked and adjusted whenever there's a reason to do it.
  4. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    There is no reason to remove the ball joints, or any other suspension parts.
    You just need to remove the axel nut and the brake caliper and rotor.
    Then you can push the cv axel joint back to access the 4 bolts, then remove the hub.
    30 minutes each side. Maybe longer if they hubs have not been changed.
    You can take a 5# hammer and punch and hit the hub to rotate it clockwise and anti clockwise
    to loosen it up while spraying with rust penetrent. Then you can hit it to pop it out.
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would do the string alignment just in case
  6. Prius_Angie
    245
    229
    Saint Louis
    Thanks for thinking of that; you are correct that uncoupling the tie rod end is associated w steering, and may require an alignment. So I wrote about it not potentially affecting alignment was not correct. But Im good in this case.
    No i don't have professional equipment to test alignment & no i dont use camber bolts on my standard struts. It is my inference by lack of added dashboard traction control lights, no tilt of my steering wheel, no added road noises and my 5 senses that tell me that my Prius continues to ride straight as an arrow on highway cruise control @70mph.
  7. Prius_Angie
    245
    229
    Saint Louis
    I will respond by quoting you "your results may vary" ;)
    I believe your experiences w hub bearings may have been much simpler for success than what I required/prefer and that's good to go. Additionally, I've done what you have prescribed before once, but it limits access for me swinging hammers from the inside of car outward & while underneath the Prius. But I chose to be more thorough for access, in cleaning, & preventive maintenance: by removing the knuckle out, it allows me for greater preventive maintenance access to view the entirety of the wheel well, seek out other potential failing parts hazards & give everything rubber a good silicone spray down on top of cleaning the whole knuckle out itself. Also, Im a big proponent of anytime & any excuse to get in under the car to see what's going on and to clean things out. This knuckle is that good excuse to get into it and clean things out. In fact, one time i noticed that my friend's 2010 Prius didn't have a wheel bearing dust deflector on either right/left front knuckle? Additionally, these bearings were well rusted (as i live in St Louis) in & I used ~50 swings each from my hammer & punch rod while atop a vise, to get both those hubs out. Metal in other dryer climate regions of the USA fair much better against rust.
    For ref an old 2005 Prius job...
    Wheel Overhaul: Hub Bearings, Brakes, Shock Struts & Sway Bars | PriusChat
  8. ChapmanF
    18,995
    Uncoupling the tie rods may affect the toe adjustment, which is one component of alignment.
    The knuckle-to-strut bolts are used for the camber adjustment, which is a different component of alignment.
    Although there are replacement bolts available with one, two, or three pips on the head that can be used when the needed camber adjustment is outside the range of the original bolts, I don't think that means even with the no-pip bolts it's just thrown back together and the camber is right. There is still a certain range of adjustment, determined by the position of the knuckle to the strut when the nuts are tightened.
  9. Prius_Angie
    245
    229
    Saint Louis
    Agreed w your sentiment about the alignment consideration & i love your string alignment idea. Thanks.
    Unfortunately I didnt notice any added dashboard traction control lights, no tilt of my steering wheel, no added road noises, & that Prius continues to ride straight as an arrow on highway cruise control @70mph.
    I've done a few of those string ones in the past & now don't even go to the pros for this small task.
    Cheap Front End Alignment | PriusChat
    tankyuong likes this.
  10. ASRDogman
    8,055
    4,083
    You chose to do the extra, not needed, work.
    Trying to bang the hub out rarely works. It just serves to seperate the hub.
    Looking at the hub from the side, hammer and punch where the bolt holes are to
    rotate the hub clock/counter clockwise. You can turn the steering wheel to get the hub
    in a safe spot to not hit the fender.
    With rust penetrant, this will free up the hub. Lot's of salt air all year in Florida, so the hub
    was rusted to the arm.
    If you have short enough bolts, you can rotate the hub so a solid part is covering the holes
    and screw them in snugly then smack the hub with a hammer then hit it again. Eventually,
    the hub will fall out.
  11. davev1pa
    davev1pa Junior Member
    34
    Lincoln,NE
    Two Eco
    Inquiring- what bearings did you install and their cost.. any issues since?
