1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2010 UK Prius T-Spirit (Nav+IPA) Android HU wiring query - reversing camera wiring
Discussion in 'Gen 3 Prius Audio and Electronics' started by Hardylane, Oct 16, 2020.
  1. Hardylane
    Hardylane New Member
    Manchester, UK
    ----UK----
    OK, here's the exact spec, and the singular problem I'm having...
    Original ICE - UK Toyota Prius T-Spirit 2010 with B9019 (non-JBL) Nav head unit (with IPA)
    I've spent DAYS trying to find info on this exact spec and no real progress... I cannot get the reversing camera to work because I can't find the connections....
    Here's the issue - I've installed an Xtrons Android head unit with its own custom harness, and it all MOSTLY works. I did have to create a +12v link to the front door woofer mini-amp however... try finding anything about THAT! (Just make a link on the harness from +ACC to +AMP on the 10-pin audio connector)
    However, the all-important 20-pin connector does NOT have the usual reversing camera pins on it (1&11, 2&12) because of this damn parking assist (which I never use and won't miss) - the camera (I believe) goes directly into the IPA controller, which is then routed to the head unit by means unknown.
    I'm loathe to run a new 4-core cable all the way to the tailgate, but I will if I have to...
    UNLESS one of you fine people have come across this issue already and can clue me in.
    Over to you :)
  2. Hardylane
    Manchester, UK
    ----UK----
    Gave up. Had to run the cables. Never mind. Pity.
  3. FlyHigh757
    FlyHigh757 New Member
    Rugby, UK
    Excel
    Hi there!
    Exactly the same position as you! Same spec car, the lot! I'm using a similar head unit to the Xtrons and noticed the front door speakers weren't working. Further investigation found a mini amp under the driver's seat, but not the JBL.
    So, all I need to do is add power to the amp?
    Taking wire G3 on headunit (ACC red) and which wire is +AMP on the original loom? It appears that all wires on my 10-pin connector are used.
    Many thanks
  4. FlyHigh757
    Rugby, UK
    Excel
    Finally making progress on this one, it may help someone with a NAV system, basic amp setup (non JBL) & Park Assist.
    Still need tips with the mini amp power though, but shall get the multi-meter on it in a bit.
    The REVerse trigger comes in to the NAV system from the IPA ECU using a grey 5 pin connector L42 and is the pink wire on pin 5.
    This can be used to trigger the reverse screen on an aftermarket head unit.
    Other wires on L42:
    Pin 1 (Red) = Parking Brake Switch Sensor
    Pin 2 (Black) = Ignition (10amp)
    Pin 3 (Violet) = Speed Sensor (Some aftermarket head units and taxi meters need this)
    The canbus from the IPA is:
    Connector L41 White 20 pin connector
    Pin 9 (Green wire) = TX+
    Pin 10 (Pink Wire) = TX-
    I will let you know if the Android system will accept these signals - Highly doubt it though!
    IPA Video (includes reversing camera):
    Connector L105 Blue Connector
    Black single wire - However it is a GVIF interface.
    This is the L42 connector
  5. g.r
    g.r New Member
    hungary
    Hi!
    I just got into a similar situation.
    Did you find out the connection point of the amplifier?
    Unfortunately, the camera is connected to the IPA ECU, from where you can disconnect a video signal
Loading...
