2010 w blown head gasket - cost to replace engine?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bminerly, Jul 26, 2019.
  1. bminerly
    bminerly Junior Member
    US
    I
    My son has a 2010 Prius with about 235K miles on it and was just told that it has a blown head gasket. He was given an estimate of about $5,000 to fix it. When I told him to ask about having the engine replaced, he was told by the same mechanic that it would cost just as much and take about 20 hours of labor. I'm no mechanic; I just own a Prius and have found it to be a good car, and have seen low-mileage replacement engines available on eBay for just under $1,000.
    Can you experts out there give me some straight info on what to expect in terms of cost of replacing an engine, whether such a move is advisable based on the age and miles on the vehicle, and whether you're aware of any good Prius mechanics in the New York metropolitan area? I'm about 50 miles north of Manhattan.
    Thanks in advance for your time and attenton.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    If your son's repair shop is using flat-rate labor time, then yes, the labor time for both jobs are similar. The labor times consider engine removal to be required for the HG replacement.
    Considering his mileage, engine replacement may make more sense than a HG replacement if the engine drinks oil. If the engine has also been running with a failed HG for more than a few hundred of miles, other damage may have occurred and a replacement engine would be wise.
    But in all honesty, a 235k mile Prius is probably not worth repairing unless he has already invested in a new hybrid battery.
    douglasjre, Raytheeagle and mikey_t like this.
    52,804
    and an inverter and brake actuator
    #3 bisco, Jul 26, 2019
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    What are we investing in:p.
    An inverter I bet(y).
    Threej and bisco like this.
  5. bisco
    52,804
    good guess :cool:
    Threej and Raytheeagle like this.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Can’t slip one past me;).
    To the OP, if not DIYing this job, you’ll be into the car a lot of $$$ and other repairs will be around the corner:cool:.
    But 235k miles out of a car is good(y).
  7. wkm
    wkm Junior Member
    california
    Local shop here will replace an engine with a rebuilt one with a 1 year warranty for 2500.00.
    Lawndale Ca. Price I was quoted - I had them do the head gasket on it and a water pump.
  8. wkm
    wkm Junior Member
    california
    Inspector858 and douglasjre like this.
  9. Triparadox
    Triparadox Active Member
    201
    108
    I had the gasket problem and I brought it to a mechanic in Stockton CA. He did it for $1,300 for me. Depending on how bad the engine is when it's gonna be put on machinery, it can go as much as $1,400. The warranty is 24,000 miles / 24 months. It took me about 6 to 7 business days to get it all done.
    A Care Auto Repair
    1102 W Fremont St, Stockton, CA 95203
    (209) 463-5600
  10. Angel209
    Angel209 Junior Member
    Stockton
    Thank you & how weird I live in Stockton as wellll
  11. Triparadox
    201
    108
  12. anon_prius
    anon_prius Junior Member
    32
    When repairing the HG, would it be much additional labor to replace the piston rings with the updated P/N from the 2016?
  13. Mendel Leisk
    42,299
    Yes. Head gasket can be done without engine removal, but ring replacement (and probably pistons) is another order of magnitude. If not mistaken the engine HAS to come out for starters. It's pretty much a complete rebuild, to do it right.
    There is an updated 3rd gen part for ring set and piston, fwiw. See attached. You want to get the complete gasket kit too.
