2010 with the shakes
Discussion in 'Gen 3 Prius Main Forum' started by Wrecit, Nov 23, 2022.
  1. Wrecit
    Wrecit Active Member
    188
    119
    Pittsburgh
    2001 Prius
    I
    Upgraded to a gen 3 and love it. Drove 9 hour from dealer I got it from with no issues
    3 days into ownership get a engine shake from stop when I hit the gas with a raw fuel smell so obviously a plug and/or coil issue. Replaced all 4 even though no code yesterday. Side note sorry about the violent thought but whoever designed the 3rd gen engine compartment needs to suffer a very slow painful death that lasts years for making you have to remove the wiper motor to change plugs.
    Drove for about an hour today and after warm up the shake is back and 20 min later it throws a P0301 so new coil and plug did not fix the misfire and it actually got bad enough to throw the code now.
    I did notice the coil connector on cylinder 1 and 3 are black while 2 and 4 are white so did someone possibly replace them and maybe not got good connection?
    Any idea why I'm getting misfire on new plugs and coils?
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Head gasket failing is most likely . It's a 10 correct? Perfect storm .. hope I'm wrong
    PriusCamper likes this.
  3. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Head gasket was replaced 2 weeks ago right before I bought it
  4. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Got the work order for it with the sale
  5. Mendel Leisk
    42,377
    What’s the miles on it? Maybe head gasket failed but EGR and intake not cleaned? Or head warped?
  6. bisco
    52,897
    were the plugs from a toyota dealer?
  7. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Plugs are denso
  8. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    They failed to repair the headgasket and ripped you off in the process.... Probably a fraudulent work order. You were doing so good with the most reliable Prius (Gen2) ever built and you decided to do the exact opposite and buy the worst most garbage Prius ever built? Why? What's wrong with the perfection of a Gen2 Prius? I'd contact a lawyer in the state you bought it in and spend a few hundred dollars to get that Lawyer to write a letter that scares the hell out of / holds the criminals who sold you this defective lemon accountable, as well as forces them to hire a lawyer to deal with all their fears that were created from your lawyer's letter.
    2010moneypit? likes this.
  9. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You should take it back quickly and tell them to repair it. Most dealerships will
    give you a 30 day warranty.
    Who replaced the head gasket? The previous owner, or dealership?
    Perhaps they failed to clean out the cooler and exhaust manifold?
    If you look inside the cylinders you might find coolant, or cleaner piston in #'s 1 and 2.
    Are you loosing coolant?
    If it possible that the connecter was repaired, but not corretly.
  10. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    If it is head gasket or EGR will it run fine for 10 to 20 minute after cold start? The shake only starts after engine warms up
  11. bisco
    52,897
    the head gasket often starts with an extremely smal leak, which may change with temp
  12. PriusCamper
    13,475
    5,441
    One person's "shake" is another persons "shutter" is another person's "death rattle." There's almost never enough details when someone says any of these related to early Gen3 Prius engine problems.
    The good news is that if you only have minor headgasket damage and coolant loss is low you can get a couple years of driving around town without much issue. Just don't drive when it's hot and don't stray too far from home/tow truck range. Once shake gets really bad you run risk of having to replace the transmission dampener.
  13. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Would say between hard shake and engine trying to jump out of the car. Seems to be worse if I have to turn and accelerate so may be engine mount also
  14. PriusCamper
    13,475
    5,441
    That'd be a relief if it was that... Seems possible...
  15. MikeV
    MikeV Junior Member
    95
    philadelphia
    did you ever get this resolved. what was the real issue. same problem Im having
