2011 bank 1 sensor 1 o2 sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by User12345, Oct 7, 2016.
  1. User12345
    User12345 New Member
    Ohio
    check engine light on, shop said o2 sensor bad. 490 for part and 117 for labor (mentioning most places want 600 for part).
    This seems way high - parts on the net are 100-200.
    Thoughts? Where is this located - can I do it myself??
  2. User12345
    Ohio
    Sorry I should mention bank one Sensor one
  3. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    Read the warranty booklet.
    I think the O2 sensor would be covered under the Federal Emissions Warranty, 8years/80K miles.
    Obviously you will have to go to the dealer to have any warranty work performed.
    If you are out of warranty, you could ask Toyota Customer Care for assistance; maybe they will cover the repair (100%, 50%, etc), or maybe they wont.
  4. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Thoughts? Yeah, my thought is, "That's baloney."
    The part costs around $100. It's not difficult to do yourself. There are lots of excellent YouTube videos showing the procedure.
    However, I believe there may be two O2 sensors on the car. You can access all the tech info from Toyota for a $15 fee for a couple of days.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Bank 1 Sensor 1 is the Air/Fuel Ratio Sensor which is mounted on the engine and is easy to access and change. Sensor 2 is the O2 sensor downstream of Cat.
  6. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  7. Rebound
    3,961
    2,609
    Portland, OR
  8. TRUC NGUYEN
    2014 Prius Plug-in
    Should be on the exhaust manifold before the catalyst converter
