2011 CT200h P0A0f
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JD Stone, Mar 5, 2025.
  1. JD Stone
    JD Stone New Member
    NH usa
    So I had an issue one cold morning (10°) went to start the car like normal. Car turned on as it should. Ag1 spun up and started the gas engine. All the sudden the car started jumping like it had a missfire. So I shut it down and tried again. Ag1 spun up and never made an attempt to grab the gas engine. Now I get a crankshaft sensor code due to the engine not turning over. But the P0A0f has me worried a bit. I'm wondering if I had an internal transmission malfunction. Any insight would be greatly appreciated. I've since gotten the Dr. Prius app when I delete the codes and attempt to restart the car. I can move momentarily on electric before it gives up. Gas engine never attempts to be started. I have gotten a wratchet on the crankshafts and I can turn the engine over by hand and feels all normal. I'm wondering if there the failure is in whatever transfers the power from electric engine to gas engine. As far as not moving far I would assume that is cause my hybrid battery is run down. Or could all these issue be due to my battery itself. The battery voltage shown is when I move the car forward a couple feet. Can someone help me with where my issue lies and what I need to replace. I don't mind pulling the transmission. Thank you
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Will your car ready Do you know what that means? If yes the minute you ready the car step on the gas did the engine just start No not the electric motor spinning the engine the engine running there is a difference your troubleshooting a generation 3 which is what your car is essentially for an engine failed to start so like any car what do you need to start fuel air and spark and at the right time most of the time the timing in the Prius or this engine doesn't really move unless something really bad has happened so fuel and spark and all that is pretty important generation 3 has a replaceable fuel pump high mileage might want to be looking and see if fuel is making it to the fuel rail like I say it's just a no start condition of a gas engine it's just like any other gas engine in a Corolla It's the same engine with a different head or different camshafts and valve timing but the same engine so maybe you have no fuel pump happening all of a sudden it is electric and all of that I see on one of your things and where you had maybe a misfire code so that would be a good time to be looking at your coils and look at the extensions with good glasses on or magnifying glasses and see if you see any places where voltage is blowing through the plastic extension hitting the metal of the valve cover It's a pretty easy thing to see actually looks like burn marks around the plastic won't necessarily be holes or anything But you can see where the plastic has been electrically compromised any of these things are going to cause you problem starting and poor running
  3. Mendel Leisk
    42,352
    What’s the miles? Has the EGR system ever been cleaned?
    You likely mean “MG1”, Motor Generator 1.
    #3 Mendel Leisk, Mar 6, 2025
  4. ChapmanF
    19,027
    Assuming the symptoms as reported, there's really no other story. Because of the way the transmission is built, if MG1 spins then either the engine crankshaft turns, or the car moves, or both, or there is mechanical breakage. If you're sure (say from eyeballs watching the end of the crankshaft) that the crank sensor code is because the crank's not turning, and meanwhile you have the zoomy sound of MG1 spinning, that's pretty much the story right there.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The image shows your hv has 1.96% charge. You need at least 40% to turn I c e over. The two bad cells in red are not good news, the salty crew need new members and can certainly pay your membership fees in a heartbeat
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Primary problem gasoline engine, misfires in cylinder 4. P0304.
    You did not deal with the first problem and created the second, discharged the high-voltage battery to its poor condition.
    First, you need to charge the high-voltage battery.
    Then deal with the engine.
    This could be a bad spark plug, a faulty ignition coil, faults in the fuel system, faults in the air tract to the engine, etc.
    The worst thing is if the engine head gasket has broken through, this can be detected by inspecting the cylinder well by the dripping drops of coolant on the cylinder walls.
    You should also check the coolant level and the condition of the oil in the engine.
    Grit likes this.
