2011 driven to no coolant - blown head gasket?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Thomas1632, May 24, 2021.
  1. Thomas1632
    Thomas1632 New Member
    Nebraska
    I
    Hello,
    I have my 2011 Prius that a friend drove with the check engine light and temperature warning light on until it stopped. Turns out the hose to the overflow/ reservoir tank had been disconnected and the system blew all the coolant out.
    They put right at 2 gallons of coolant back into it (7.6 or 6.9 qt capacity! and the overflow tank is still low)
    The car gives a "check hybrid system" on the display and will not start.
    A code reader gives a P3191 code.
    Erasing the code allows the system to reset and the engine will start, but it only runs for 15 seconds then shuts down and throws the P3191 code again.
    I also have pink coolant that drips from the tail pipe....like a fairly significant quantity by now.
    Is this a likely blown head gasket? Any suggestions on how to start diagnostics for this or other things to check first?
    Thank you,
    Thomas
  2. GustoGuy
    GustoGuy Member
    82
    57
    I would get a low mileage JDM engine. My engine hydro-locked last fall on my 2010 Prius and I bought a JDM engine off of Ebay. Check with a garage for a quote on how much it will cost to replace the engine and if you can bring your own engine in.
  3. Mendel Leisk
    42,345
    Unfortunately nobody (until just now) noticed OP's question, and he only posted the once, likely gone. But just in case:
    Leak-down test is best for head gasket diagnosis.
  4. Samuel Williams Jr
    246
    Dayton NV
    Most likely the engine is toast? If it overheated enough to stop? Then it could having bearing and or cylinder wall damage? Not to mention a cracked block or a warped head? It's a very expense gamble if you plan on paying someone to do the job? Likely it would not be much more for a used motor to replace this one?
    But if you can do the HG, job yourself? WTH, give it shot. But paying labor rates to have a shop do the job with this motor is a very high risk gamble.
  5. ChapmanF
    19,020
    Leak-down test is probably superfluous if you have visibly pink coolant dripping in "fairly significant quantity" from the tailpipe.
    The test can be more useful if applied somewhere before the sweet-white-clouds-from-tailpipe stage.
    #5 ChapmanF, Jun 21, 2021
    Ed Beaty and Samuel Williams Jr like this.
  6. GustoGuy
    GustoGuy Member
    82
    57
    I agree. Like Dr Mccoy on Star Trek would say "She's dead Jim" The engine was ran without coolant there will be major damage. I would look for a reasonably price low mileage engine to replace the damaged engine.
    Samuel Williams Jr likes this.
