2011 engine rattles HARD on startup after sitting a couple of days
Discussion in 'Gen 3 Prius Main Forum' started by BlackPrius001, Aug 8, 2025.
  1. Mendel Leisk
    41,785
    BTW, if you want to partial-quote, you can select some text, then click on the "Reply" pop-up. I never bother with "+Quote", I think it's for mutiple quotes, but you can manage that with just "Reply".
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    8 months, 4 weeks, 3 days and 45 seconds.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,374
    6,494
    Texas Hill Country
    Given you are in Austin with the 85mph freeways and the incredible heat buildup in traffic - and it's an oil burner, you may need a replacement engine fairly quick. Yours could throw a rod through the block which would definitely ruin your commute home in 100f weather.
    It's piston and rings along with a rebuilt head and reasonably speaking, a revised egr valve with updated ecu software. Along with extensive cleaning, timing-chain alignment and sealing.
    You can get a better engine at the local JDM used in Japan distributor than you will end up with trying to rebuild yours. Even if you use 90% of the pro shops around Central Texas.
    100k miles guaranteed needs a rebuilt engine from Hybrid Pit shipped to your shop. The only better gen3 engine is a dealer rebuild with a new short block and rebuilt head for $8k. The car is not worth that much.
    A JDM is around $1500 plus install which any shop can do. If there are any immigrant shops left open I would find one and start socializing without a red hat on.
    A new Hybrid Pit frankengine option takes a gen4 short block, adds a gen3 rebuilt head, a gen4 cam assembly, a gen3 intake and your egr for mechanical and electrical compatibility.
    The other option is to trade it while you can and get a much newer gen4 Prius, Rav4 or convert to a conventional Corolla, Camry or Civic in your price range.
    A more optimist view would be drive it as long as you can while saving for a good engine or a down payment on something newer. Most people take the "let's see what happens next" approach snd occasionally get six months to a year before it's rattling at every stoplight and belching white smoke out of the exhaust.
    #23 rjparker, Aug 10, 2025
