2011 Lexus CT 200h
Discussion in 'Lexus Hybrids and EVs' started by kmkremer, Mar 3, 2010.
  1. minnie_m
    minnie_m New Member
    texas
    2001 Prius
    At the time of its release, the Lexus CT was considered as one of the quality sedans in its segment.
  2. minnie_m
    minnie_m New Member
    texas
    2001 Prius
    The Lexus CT hybrid is one of the advanced hybrids in its segment; it is a 4-door hatchback that can accommodate five adult passengers.
  3. minnie_m
    minnie_m New Member
    texas
    2001 Prius
    Lexus CT is designed with an efficient electric/gas drivetrain which directs the produced power to the front wheels. Close rivals to Lexus CT hybrid are the Mini Cooper Clubman and Volvo C30.
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    ^ you sound like a spokesperson. oO
  5. peterjmc
    917
    189
    Clarksburg, MD
    I want these seats. Looks like they would have better thigh support that the Prius V.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You from the future?
  7. macmaster05
    4,050
    730
    Minnie_M is a commercial spokesperson from the future, you know like the ones in Minority Report that speak to you when they scan your retina.
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Well, it is officially priced less than the HS...
    The new Lexus CT 200h is truly a different kind of hybrid. Arriving in March 2011, it has an EPA-estimated combined rating of 42 mpg [1], the highest of any luxury vehicle [2]. Not only that, its aggressively styled exterior is designed to help improve handling and reduce drag. With a starting price of just $29,120 MSRP [3], it's easy to find out for yourself how innovative the CT 200h really is.
  9. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Mostly Loaded:
    CT 200h
    Exterior Color: Obsidian Interior Color: Black Leather Wheels: F Sport 17" Inch Alloy Wheels $1,300 Remove Moonroof and Heated Seats Package $1,780 Remove Premium Audio Package $1,125 Remove Premium Audio package (Requires Navigation) $1,100 Remove Navigation Package $2,445 Remove Premium Audio Package with Rearview Mirror Back-up Camera $1,475 Remove Leather Package $1,330 Remove LED Headlamps $1,215 Remove One-touch Moonroof $0 Remove Heated Front Seats $0 Remove Back-up Camera $550 Remove Pre-collision system $1,500 Remove Accessory Dash Panel - Wood $199 Remove Accessory Dash Panel - Bamboo $199 Remove Accessory Dash Panel - Striated Graphite Metallic $199 Remove Lower Door Molding $240 Remove Remote Engine Start $375 Remove Glass Breakage Sensor $299 Remove Car Cover $199 Remove Door Edge Guard $0 Remove Mirror Cap $0 Remove Paint Protection Film $429 Remove Rear Bumper Applique $76 Remove Rear Bumper Protector
    (Metallic Finish) $145 Remove F-Sport Sway Bars $599 Remove F-Sport Lowering Springs $399 Remove Cargo Net – Vertical (Integrated Pockets) $75 Remove Cargo Net – Spider $49 Remove Cargo Liner $150 Remove Illuminated Door Sills $299 Remove Premium Carpet Floor Mats $265 Remove Cargo Tray $90 Remove Carpet Cargo Mats $79 Remove Wheel Locks $73 Remove Delivery, Processing and Handling $875
    Total MSRP* : $44,257
  10. Tideland Prius
    16,678
    You have a few packages that overlapped... (or was that taken into account?)
  11. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Pics I've seen seem to show a heads up display. Let's hope it works better than GM's.
    Still a bit skeptical that HSD will ever facilitate fast cornering, too much lag (at least in the Prius) to have any hope of balancing the chassis with throttle inputs. But I'm all for more and different executions of the hybrid idea, to open up the market and our minds in the process.
  12. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    :confused: We had it in a GM car and it work great so I really do not know what you writing about
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The overlapping packages is required. If you want option X then it requires you to select options Y and Z with similar names.
    And @ Pinto, what lag? The HSD inherently has 0 lag because of the electric motors. The Prius is not a bagillion horsepowered car though, so it is not a fast accelerator/decelerator but as far as throttle lag there is none. If you testdrive any of the Lexus hybrids, the only change (other than the higher voltage pack) is a beefier motor. In every case the HSD increases performance of the vehicles.
    Lexus in general is not a racing feel. Even the ISF feels "Lexus-y". Have not had the option to drive an LFA though! :) But I enjoy that feel.
  14. Tideland Prius
    16,678
    Err, not in this case since there are 3 different Premium Audio packages depending on whether you want the backup camera or whether you have the navigation package or not. You can't have all 3 premium audio packages in the car at the same time.
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    No, but you cant select one without the other. They build on eachother.
    I used the Lexus "build your own" in an email link minutes after the email was received. When selecting one package, it says you cannot have it unless you select this other package. Then when you select that, it says you cant have it unless you select this again other package. Perhaps a bug they have since fixed, but there are two distinct messages that came. The first being you need package Y to add package X. The other is you cannot have both package X and package Y. So the maxed out model has no duplicates according to Lexus.
  16. Tideland Prius
    16,678
    Must be a bug. When I was reading the options list in the other CT200h thread, the nav pack requires the Premium Audio package that costs $1,100. The leather package requires the Premium Audio Package #1 ($1,125).. the $25 gets you a compass in the mirror which isn't necessary with the nav pack. Now I assume if add the two (leather and nav), you wouldn't need Premium Audio #1 since the nav pack covers it.
    Ditto if you order the PCS/DRCC.
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    CT200h gives a better value than the Volt. I know they are for different people. CT200h costs $10k less than that Volt because there is no $10k battery that requires plugging in. CT200h gets better MPG in CS mode and has more interior room as well.
  18. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
    Funny I never thought to compare but when people see the price of a "Chevy" higher than a "Lexus" I think it will sway some people.
  19. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Those with the money to buy the volt, wont... It is a chevy, and that brand name cant be changed. Slap a caddy emblem on the back, and it might sell.
  20. Tideland Prius
    16,678
    Yeah we all know how that fared (Cimarron anyone?)
