2011 Lexus CT 200h
Discussion in 'Lexus Hybrids and EVs' started by kmkremer, Mar 3, 2010.
  1. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It's a fair statement. I wouldn't buy either, but some will.
    We are on our 3rd Lexus RX, but we could have just bought the Toyota Highlander. Same car, different trim level, different badge, way different price.
    When you price a car at $40k, you are trying to attract those with that sort of cash to blow on a car. Of those out there, most will buy German or Japanese because usually wealth comes with intelligence. The other small percent that will buy Big3, dont want to bring home a Chevy.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Volt is probably the most expensive car with the rear torsion beam suspension.
    CT200h rear suspension is double wishbones fully independent.
  3. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    Quite possibly. The highest I could find w/ torsion beam is a 2011 Sienna @$37,000
  4. Tideland Prius
    16,680
    What about the most expensive car with Leaf Springs ;)
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    LOL, no idea... it maybe a truck. CT200h is probably the first car to equipped with the stock lateral performance dampers.
  6. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Have you ever driven a car with a manual transmission, driven it fast, balancing the chassis through corners with small throttle inputs? If you have, you'll know what I mean.
    At speed in the G II Prius, even large throttle inputs were ineffectual, the lag must have been 1/2 second or more, which is an eternity in this case. It was even worse than a car with a traditional automatic transmission. It reminded me of a car with lots of turbo lag, by the time the power arrived it was too late.
    But it's not a performance car, so to some degree that wasn't a huge issue, just one of those little things which for me diminished the fun of the driving experience.
    Definitely not interested in the Lexus hybrid, four door sedans are not my bag.
  7. Tideland Prius
    16,680
    Might be a case of the electronic throttle (well that and the fact that the engine has to fire up). Our Camry exhibited the same delay if you floor it.
    It's not a truck :)
  8. Pinto Girl
    3,093
    350
    Yep, the car was thinking a lot, I could feel it. And the thoughts it had were something like, "Pinto, why are you driving me like this?"
    Power was flowing in one direction then another, the ICE was revving then backing off, power needs constantly balanced and rebalanced between electric and gasoline power, those gears in the HSD were doing their thing, speeding up, slowing down, even reversing if memory serves (?) and all of it added up to that lag I mentioned.
    Also there was no way to hold it in 'gear' if you will, as soon as I let off the throttle it was immediately seeking maximum mpg again, when I still wanted maximum mph.
    But like I said, that's not what it was designed for. And I always tend to expect a lot from mechanical devices, it's just who I am.
  9. Tideland Prius
    16,680
    PWR Mode ;). It's like an on-off switch... well for us non-racing types.
  10. UsedToLoveCars
    448
    102
    Current model Corvettes.
    yes, really
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I've driven and own manual transmission cars. The Prius gets the correct "gearing" faster than most people can manually change gears and floor it for the extra power. If you are driving along in a power zone already and cruising down the highway then that is a waste but the power is immediately available in a manual. But the rational thing to do is to drive in the lowest gear needed. So when it comes time to pass, you either suffer the power lag or shift down pass and shift up.
    I find the Prius to be very zippy and fun to drive. And I have driven many cars and many more expensive than the Prius.
  12. UsedToLoveCars
    448
    102
    throttle-by-wire should have no perceptible lag, if that's what you mean.
  13. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Exactly. The manual transmission driver doesn't feel the lag because he/she is too busy thinking/shifting/lagging. I know shifting becomes 2nd nature but people do make mistakes and it takes longer to correct it.
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Wow, I looked it up and it is true.
  15. Tideland Prius
    16,680
    Yeah that's what I meant. There's a lag between when the pedal hits the floor and when the engine revs and the car moves. It seems like you get a better response if you slowly increase the pressure instead of just flooring it.
    We have ourselves a winner:cheer2:
  16. coach81
    coach81 Active Member
    758
    116
    Louisiana
    When will this car hit the dealerships?
  17. penquin230
    penquin230 "Golden Hawk"
    85
    Atlanta, Ga.
    Coach I believe they said it would hit stealerships in March 2011.
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    yep - March
    Lexus: Darker Side of Green
  19. coach81
    758
    116
    Louisiana
    cool... good to have choices...
  20. Michaelk
    Michaelk New Member
    44
    Would love to have one if it rode and was as quite as our ES Lexus. Wanted a BMW and drove both. After driving the Lexus there wasn't a comparison.
    Do you think they will sell as well as the Prius?
    Michael
