2011 Option - Nitrogen in the tires
Discussion in 'Gen 3 Prius Main Forum' started by ben12345, May 10, 2011.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I'm afraid a dealer like this will also screw you over on maintanance. You might be best advised to buy elsewhere.
  2. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    No, you can get a water separator, but it's aftermarket, and it goes on the output, not the input. Anyone who uses their compressor to paint has a water separator.
  3. Mendel Leisk
    42,296
    Nitrogen fill will tie you to the dealership, and/or Costco and others who offer it. Pure nitrogen fill a little less prone to bleed out of the tires, might be beneficial to the rubber as well. I would walk on that, it's mostly bull.
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Nitrogen option is worth exactly $0, it's a bigger scam, not in price but in the pure insanity of it, than the $300 pin stripes that used to be the rage as an option on a car.
  5. Much More Better
    Much More Better Active Member
    655
    163
    Don't count on it. I used to pump my tires up at a Shell gas station, until I realized how much water spits out of that thing. I hope that was the exception rather than the rule. Anyway, I don't even wanna get a small, handyman-type compressor for tire inflation purposes. I don't want another tool to put away, water to worry about, noise as it fires up.....
    I just use a floor standing bicycle tire pump. When I would top up 1-2 PSI, it takes no time.
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Some of the water that is perceived to be in the air coming out of the compressor actually is just condensation from the outside air. When the compressed air is decompressed, it rapidly cools, causing condensation in the air it is mixed with.
    If you empty and drain your tank, the air you pump into your tires ought not have any more water vapor than in the air that the compressor takes in.
    If you want to try an experiment, try taking a nitrogen filled tire, bleed it and see if it feels "wet" like regular air.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If a compressor is maintained, the tank gets drained frequently. Many large shop compressors have an automatic drain that lets a small shot of air with any accumulated water out of the bottom of the tank. So, the air out of compressor will normally have less water than the air that went into the compressor. The compressor is removing water from the air, not adding it.
    OTOH, air from a bicycle pump or tankless compressor will still contain all the moisture that was in the air.[​IMG] It's exactly the opposite of what "common sense" tells people.
  8. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I put nitrogen in my tires a year ago, and have no regrets. It included free rotation .... I would have spent far more on rotations than the nitrogen cost.
    That said, I just installed 4 new Michlien Energy Saver tires ... and did not put nitrogen in ... but I may later.
  9. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Hold out for the 110% Nitrogen. Better value for the money.
