2011 Prius 2 warning lights on.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tammyvoje, Aug 31, 2015.
  1. Tammyvoje
    Tammyvoje Junior Member
    33
    My 2011 Prius has the abs light and traction control light on. The car has sat 4 days I go and start it and the lights are on. Not blinking steady. I just filled the car Friday could it be the gas cap not tight?
    Help please, husband out of town and dealer two hours away.
    52,595
    check the tyres pressure.
  3. Tammyvoje
    33
    I have, nitro in them . Any other ideas?
    52,595
    have you hit any curbs? could be a bad bearing or speed sensor.
    best to check your 12 volt health first. if that's good, you'll need to have the trouble codes read.
  5. Tammyvoje
    33
    I haven't, I had my tires rotated and than this happened. Has me wondering.. Any thoughts?
  6. bisco
    52,595
    i wonder if over torquing the lugs could affect anything? might be worth pulling them off and checking free wheeling. how many miles on the tyres?
  7. Tammyvoje
    33
    I'm not taking the tires off, I'm 53 lol.
    It's going to the shop Tuesday,
    I think it has to do with the rotation.
  8. bisco
    52,595
    53?!? i'm 60, and i took the tyres off last week! of course, i've been on advil and bed rest since then.(n)
  9. Tammyvoje
    33
    My husband gone, I can't do it alone.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    A problem with the gas cap would probably only be a check engine light.
  11. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Someone probably messed up a wheel speed sensor, or sensor wire while rotating the tires. Take it back to the shop that rotated your tires. Make them inspect around the hubs for damaged or disconnected wires/harnesses.
