2011 Prius 200k miles
Discussion in 'Gen 3 Prius Main Forum' started by Ocskip, Aug 21, 2019.
  1. Ocskip
    Ocskip New Member
    Garden grove
    Looking to buy a 2011 Prius 2 with 200,000 miles. One owner, no accident , good shape for 5000. Is that a good deal? Any concerns ?
    Thanks
    52,475
    welcome!
    sounds high to me, but prices are geographic. check kbb.com
    lots of issues on the gen 3, but getting to 200k might be a good sign :p
    scan through the maintenance and troubleshooting forum for a feel of all the expensive systems, and the technical knowledge needed to mitigate the expensive repairs through diy.
    all the best!
  3. Mendel Leisk
    41,999
    Sadly, if this was a typical, bring-it-to-the-dealership-regularly owner, it might have a very clogged intake manifold and EGR system, and a PCV system that has turned the bottom of the intake into a oil/water swill swimming pool.
    This can be remedied, by a proactive owner, but by 200K miles, if nothing's been done, I'd stay away. With that amount of miles and no remedies, the head gasket could be nearing failure, and/or it's an oil burner.
    #3 Mendel Leisk, Aug 21, 2019
  4. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    See private sale section of forum.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I sold our 2010 earlier this year with 300k miles on it for $4500;).
    And I did a lot of preventative maintenance to it:).
    So I’d vote for its high, but if the owner is willing to dicker, might be a good buy(y).
  6. bunny45
    bunny45 New Member
    Germany
    Hi Ray, greetings from Germany.
    In what condition was the traction battery after so many miles? What kind of milage were you getting before you sold it?
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The battery was fine:).
    But I used the Prolong equipment to recondition it;).
    I was at ~50 mpg at sale time (y).
  8. cuevrojamez
    cuevrojamez Junior Member
    Missouri
    I’m picking up a 2010 Prius II with 212K mikes for $4500 next week. Depending on your location, that price doesn’t sound bad.
  9. Nenepopz
    Nenepopz Junior Member
    NY
    2020 Prius Prime
    Currently have a 2011 Prius with 160k on it and drives beautifully no issues so I have no worries it will make it to 200k. I’m on original hybrid battery and little to no maintenance other than oil changes and tire rotations..price seems ok tho I believe mine was quoted lower with less miles? Either way, good luck it is a great car!
