2011 prius 3 bad wheel bearing hubs
Discussion in 'Gen 3 Prius Main Forum' started by Mharris2017, Aug 17, 2025.
  1. Mharris2017
    Mharris2017 New Member
    United states
    I
    I have a 2011 base model prius. It developed the rear driver side wheel bearing hub humming 165,000 ish miles. I sent the prius to Firestone for wheel bearing hub assembly replacement. They had to put 3 different hubs into it all the new ones they installed had the been defective ranging from normal replacement to premium quality. All of them once installed had various problems. They are installing new oem one currently. Is this a common problem for prius aftermarket hub assembly's? Thanks Marshall
  2. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    I don't know man I guess it could be a location thing maybe people are beating on the bearings to put them in when they don't need to who knows . I can't see them installing them from here and they don't let you in the shop on purpose so. You just never know in this day and age a big hammer is a top tool in many shops. And you see how your local kids are doing . Well they're you're new meccies. I know scary or maybe should be. But you are experiencing what everybody on this chat has been talking about for years apparently I have never had this experience with four cars and nobody touches them but me my bearings get put on by me not my son or front of house but etc . So I don't know what they're doing on my crap I've got bearings on corners of all 4 these things that range from 39 bux a pop to over 150 a pop . So far in 7 years or so . NONE have failed or started making a racket or any of that . I've a lifted Prius too same situation my cats go off the pavement very regular room still nothing . I live in derp souf USA . So if anything was going to be fubar it would be around here . Go figure. That's 16 bearings here on site on the ground 25 7 365 and cars all on the 20 year marks more or less . Wish I had an answer.
  3. Mendel Leisk
    42,330
    Dealership? Maybe next time.
  4. Mharris2017
    United states
    I
    Thanks for the reply im going to change the others myself next time.
  5. Mharris2017
    United states
    I
    They're replacing it with toyota oem this time under warranty. Im most likely going to do it myself next time.
    Mendel Leisk and ASRDogman like this.
  6. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    It's sad because almost every manufacturer has gone to china to make there parts because it's
    cheap labor. But they also use cheaper parts, cheaply made.
    trq used to be a good product. Not any longer. I had 3 sets of hubs that only lasted 4000 miles.
    I finally bought timken rear hubs that lasted well over 100,000 miles. And I replaced them when I
    thought they were making noise, they weren't.
    For the fronts I bought MOOG hubs. Same mileage for them,
    I replaced them when I thought they were making noise, they weren't. It was the tires....
    I replaced them with autozone hubs that they say are made by moog. I've got about 20,000 or more
    miles on them without an issue.
    But make sure they are MADE IN AMERICA! Because moog also gets them made in china.
    So make sure they are the ones mad in America.
    #6 ASRDogman, Aug 20, 2025
