2011 Prius aftermarket audio
Discussion in 'Gen 3 Prius Audio and Electronics' started by Sheon, Mar 25, 2011.
  1. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    ^Haven't had such lockups happen with the JVC I mentioned above (hint hint). ;-)
    To answer the original question, it could perhaps be overheating? Or it might be something as mundane as a software bug.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No, it is not common unless specific to that model. We have Kenwood units in the display board that play 8hrs a day, 5 days a week and they do not reboot like that.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    My 6960 has been solid. I believe 9960 (last year flagship model) had instability issues in the beginning and then they fixed it with later firmware.
    You may have to wait for newer firmware. I don't see any update for 9980 yet.... Check on kenwoodforums.com to see if other owners are experiencing the same. If they are not, it could be the install or a defective unit.
  4. frodoz737
    frodoz737 Top Wrench
    4,797
    2,560
    33
    In addition to what usbseawolf2000 said, be careful of the reset button (red triangle) right below the menu selection. It is slightly recessed, but I accidently hit mine once. Call Kenwood.
  5. Sheon
    Sheon Junior Member
    35
    Hawaii
    I
    thx so far it has not done it again if it does it again ill call up kenwood
  6. Sheon
    Sheon Junior Member
    35
    Hawaii
    I
    im still rocking the kenwood deck no more issues at all with it rebooting :)
    i did do the update and it didnt seem to change much
    deck still has amazing sound quality :)
    now if kenwood can just fix the damn album art issue................... i hate waiting 10 seconds for a song to change -_-....
    GPS still works amazing i love how it saves all ur recent searches :) very usefull
  7. frodoz737
    4,797
    2,560
    33
    Glad things worked out for you. I still love my 9960 based system as well.
  8. RMG916
    RMG916 New Member
    Sacramento, CA
    Does anyone know where or how I could start to find a TV monitor for the back seat? Should I put them in the headrests if thats possible or get a monitor that attaches to the two front seats? hmm. HELP!!!:(:(:(:(:(
  9. Hank101
    Hank101 Member
    108
    SC
    Common problem with low voltage supply. Common solution is to feed a direct line from the battery, wired to a relay, switched on/off with stereo power source.
    I had the same problem, which was fixed as per above. You can get the relays anywhere (best buy, ect..).
  10. Zephyr7
    Zephyr7 Member
    301
    28
    Sorry to a digger
    have U found anything that plays flac/ogg?
    none of the factory installed system plays those format. the Merc aftermarket and the new Pioneer App Radio does I think. though they are free codecs there is no demand to enable these loessless format on cars which has nice sound system.
