2011 Prius, Alpine INA-Z928HD installation!
Discussion in 'Gen 3 Prius Audio and Electronics' started by BlackSpade317, Oct 2, 2012.
  1. nelsc
    nelsc New Member
    I'm not by it but it has the 5 min mpg average I believe and power distribution. In set up you can change which doors unlock when keyless is activated and things like that. I can't remember all of it till I'm in the car.
  2. peterjmc
    917
    189
    Clarksburg, MD
    You can setup door unlock commands through the radio!?
  3. nelsc
    nelsc New Member
    What features will be lost
  4. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    anyone tried it ? I'm curious how it'll fit with the ipad mini :)
  5. pb500
    pb500 Junior Member
    16
    Hello, hope you're still monitoring this thread. I am doing the installation now, and have questions. I was wondering if you have the same issue as I have. There were 4 plugs that went into the original standard radio. There are 4 plugs on the Alpine Perfect Fit wiring harness. One does not match up with the Toyota plug.
    Did you leave it unplugged, or did yours all 4 fit together? (BTW, I also purchased a PAC TR7 Module to make the brake hook-ups easier.)
    Did you hook up a rear camera, and were there any Toyota pre wired wires you used?
    Thanks.
  6. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Id like to know if your able to keep the steering wheel controls
    SCH-I605 ? 2
  7. pb500
    pb500 Junior Member
    16
    The Perfect Fit system come with a module that allows you to keep your steering wheel controls.
  8. riceroni87
    360
    598
    Oxnard, CA
    thats good to know. I may look into this instead of the myron and davis unit. I love how big the display is.
  9. pb500
    pb500 Junior Member
    16
    Currently, I'm taking apart the interior trim to run all the wires needed to the external mic, and the rear camera. Alpine has a promotion for a free camera with the purchase of the radio. But video cable from the front to the rear is not included.
    If you've never done this before, there are a few YouTube videos showing how everything comes apart. The only issue I have right now, is if I got the correct wiring harness, because one plug does not match the Toyota plug. It may be for an auxiliary thing that doesn't need to be hooked up, so I'm hoping the original poster replies here.
  10. CdotK
    CdotK Member
    376
    46
    that looks sweet!
  11. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
  12. pb500
    pb500 Junior Member
    16
    Well, so far I had to trim the metal and guide holes just a hair on the mounting brackets that came with the Perfect Fit system because the radio was off a little to the left and up. This interfered with the front panel opening and closing. Now it's centered and it looks and works great. I still have to connect the brake wires for the GPS and DVD to function correctly, but it does tell me where I am at the moment. The rear camera has to wait until I get a video cable run from the rear.
    I suspect the plug that doesn't fit on my harness goes to the steering wheel controls because they do not work right now. I do have the steering wheel control adapter hooked up to the radio, so it must not be out-putting a signal to the steering wheel buttons.
    I also have no idea where to hook up the speed sensor, or why it is even needed. Any help would be appreciated.
  13. frodoz737
    4,798
    2,560
    33
    Installed a custom system in my 2010 II frodoz Stereo Upgrade | PriusChat and may be interested in this HU. Can you confirm the surround/bezel provided by Alpine matches color and texture for this vehicle as stated on their website. While planning before, I found the "Metro" and other aftermarket piece to be sub-standard painted matte finish items. This is why I used the "European" Toyota piece then.
  14. pb500
    pb500 Junior Member
    16
    The bezel looks factory made.
  15. pb500
    pb500 Junior Member
    16
    Well, I'm slowly answering my own questions. The plugs from the radio to the steering wheel controls are different for the 2010-11 and the 2012 and up Prius. So I have the wrong wiring harness.
    After I get the correct one, I'll hook up the rear camera, and brake controls. Only the speed sensor wire is left. Can anyone help me with that?
  16. CygnusX-1
    CygnusX-1 Junior Member
    I had the same issue with regard to the speed sensor. I can tell you that it is not required. My system is fully functional without it hooked up. I'm not sure why Alpine includes the speed sensor wire and neither is our local Alpine dealer. The unit gets your speed from the GPS system. It may be there just in case the GPS doesn't have a lock, but if that is the case why do you even care what speed you are going.
  17. pb500
    pb500 Junior Member
    16
    Thanks. I was wondering, since my GPS does work correctly, AND even told me what the speed limit was, where I was driving. I guess it noticed I was going 5 mph more than I should have been going. ;)
  18. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    I see you have the Prius III with the JBL system. Did you have to install an extra converter for the JBL amp to work with the Alpine head unit?
  19. pb500
    pb500 Junior Member
    16
    The person who started this page has not responded to my questions, so I don't think he is monitoring it anymore. However, I do know that if you order this HU and the Perfect Fit package, they will ask you if your car is JBL equipped or not, and give you the appropriate kit.
  20. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    thanks for the info. where did you buy yours? I have seen it advertized from $999-1499.
