2011 Prius ATF Drain and Fill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by calirider, Jun 5, 2015.
  1. southtxprius
    southtxprius Junior Member
    78
    South TX
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    No, those are for the much smaller oil drain plug washers.
  3. southtxprius
    78
    South TX
    Ok, thanks. Can someone tell me the part number for the ATF gaskets?
  4. xliderider
    8,140
    3,280
    Honolulu, HI
  5. southtxprius
    78
    South TX
  6. calirider
    calirider ECOmobile
    105
    33
    California Central Valley
    I just got one for the drain plug from the dealership. Those little parts are best to buy from the dealer when you get the ATF.
  7. oldasdust
    oldasdust Member
    356
    47
    illinois
    Did mine at 60 and will have it done again at 100
  8. Mendel Leisk
    42,355
    Maybe show them this?
    frodoz737 and Boston Jim like this.
  9. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Should not cost more than $150.
  10. Mendel Leisk
    42,355
    Tideland Prius got his changed at a dealership for something like $79.95 (Can), which is quite good. Having done it myself a couple of times, I'd say anything under $100 is reasonable.
    When I last bought liters of Toyota ATF-WS they were $9.32 (Can), four required.Plus the fill and drain bolt washers were $1.99 (Can) each. For a shop with a lift I'm sure it'd only take them about 1/2 hour.
  11. Boston Jim
    Boston Jim Active Member
    202
    148
    Thanks
  12. southtxprius
    78
    South TX
    The excerpt from the repair manual was SO helpful. I ended up going to the dealer today (the one in town that said that they WOULD consider doing the service!) but still had to show them the repair manual twice. I may attempt this maintenance myself in 30K or so, but I'm satisfied with the Dealer's service for this time.
    Cost breakdown:
    4 Qts ATF-WS Fluid $36.80
    2 90430-A0003 Gaskets $ 3.22
    Labor (0.7 hours) $63
    Total pre-tax: 103.02
    At 87K- here is what the old AFT-WS fluid looks like. Pretty dark!
  13. calirider
    calirider ECOmobile
    105
    33
    A dealer that did not even charge one hour, amazing. One hour minimum on every labor rate I have seen.
  14. southtxprius
    78
    South TX
    They might have felt bad- I paid for a brake inspection, too (not the usual free "quick look") and they were dragging their feet on doing the ATF change. They did the fluid change after they finished with the brakes. I spent WAY too long at the dealer that morning!
