2011 Prius Base - 12v Battery replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Joe Mc, Jan 15, 2025.
  1. Joe Mc
    Joe Mc Junior Member
    Levittown, PA
    I'm located in N/E Pennsylvania, USA.
    I plan to replace the 12v battery. I perform all maintenance that I can myself and consider battery replacement a very easy task. However, this will be my first with a hybrid.
    I'm asking for your experience with 12v Battery replacement:
    • Installation procedure - like any other battery replacement = disconnect negative then positive, remove hold down, etc. Or is there another specific procedure = I.E. "before disconnecting do this first"?
    • After installation - anything other than, check vehicle for normal operations?
    • Will disconnecting battery wipe out saved radio channels and trip odometers and/or fuel mpg?
    • What brand did you get
    • Where did you purchase
    Considering Maxx Start (Wallmart) because I've had excellent past experiences with them = 99 Dodge Ram w/diesel bought in 5/2001 and after OEM batteries started to fail in late 2005 I used these batteries. They seemed to last me 5-6 years.
    I appreciate your reply and shared past experiences.
  2. Tombukt2
    Tombukt2 Senior Member
    13,822
    2,508
    Durham NC
    This has been hashed out here the last 15 or 17 years or so so plenty of reading 12 volt batteries are pretty subjective so it was always that and now they are extremely costly versus 20 years ago so there's always that warranties are prorated as always so there's always these things and it's a good game at best I've had good luck with the die-hard AGM looks like it's got blue water or something on the front of the label. Generally problems with the 12 volt are usually the owner's fault A flooded battery tray that's frozen in the winter and leaving stuff on You can't blame the battery manufacturer for human shortcomings.
  3. Brian1954
    Brian1954 Senior Member
    2,665
    1,066
    South Central PA, USA
    Replacement of the 12v battery is no different than any other standard car.
    Yes, you will lose the radio station memory.
    I will be buying a battery from Walmart when my present battery goes bad. I am hoping that will be in 2 to 3 years from now.
    Joe Mc likes this.
  4. Danno5060
    Danno5060 Active Member
    405
    208
    Wyoming
    As opposed to a "normal" car, it's a little different because of its location.
    If you've got a bunch of stuff in the back, you might have to pull it out to get the floor panel out.
    Because it's buried down in a hole, you don't want to drop a socket or one of the screws too. (The first time I changed out the battery in my Gen 2, which is similar, I dropped one of the screws or a nut. Finding it and digging it out turned out to be the hardest part of changing out the battery).
    I found it's easier to remove the bolt holding the ground lead to the body, then removing the negative battery clamp when you've got the battery out to be easier than removing the negative battery clamp when the battery is in place. That may be just me though.
    The cover over the positive battery clamp was also a little bit of a trick to figure out how to get it opened. Still, not much of a problem.
    You may also find the vent tube to be something you're not used to. Keep from crushing it when you put in the new battery. If the tube is stretched out and won't stay on your new battery, maybe you'll need to trim just a little bit off (1/4" to 3/8"). If your new battery doesn't need the vent tube, maybe tape it up where the next person can still use it.
    Like @Tombukt2, I got a DieHard AGM the last time I changed out the battery. I also changed out the 12V battery in my 2019 Prime and just for the heck of it I called the dealer. They had one in stock for less than any of the replacements, and it had a better warranty spec than anything else I could find. If I needed to change the battery in my Gen 3 today, I'd probably see what the price/availability would be from the dealer too.
    I got a Super Start (O'Reilly brand) battery for my Gen 2, and I wasn't impressed by how long it lasted. It was still under warranty, but when it needed to be replaced about 2 years later (3 year warranty), I took the pro-rated refund and bought the DieHard from the Advance Auto across the street.
    That's all I can think of.
    #4 Danno5060, Jan 15, 2025
  5. Joe Mc
    Levittown, PA
    Thanks for reply.
    I'm sort of new here, although I'm familiar with other forums for different vehicles I did look for but didn't see a "search" method. Probably just didn't look well enough.
    Anyhow, indeed cost of batteries has gone insane. When I purchased 2 new batteries for my old truck (2005) they were $50 ea. Last pair (2024) were around $200 ea.
  6. Joe Mc
    Levittown, PA
    Danno5060,
    Thanks for reply.
    Will have to look into cost of a Toyota dealer battery. Closest to me is around a 2 hour round trip so...
    Car a has almost 140,000 miles so who knows how much longer it'll keep keeping on? I love this little car and have maintained it well. Regardless, it could die tomorrow - you just never know.
    My wife had a Miata and then a Volvo xc-70, so familiar with vent tubes.
    I did pull out all the panels to access the Prius battery trying to find date code (no luck) and it is fairly well buried, not too bad. Appreciate tips on screw removal, dropped many fasteners over the years and dread when they just "clink" and you don't hear the thud when they hit the floor. Always seems they stop somewhere you can see them and a mirror, flashlight and extension magnet is needed to hopefully retrieve. Same deal with sockets that just fall off the extension...
    Thanks again
    DogDaze and Danno5060 like this.
  7. Danno5060
    405
    208
    Wyoming
    The cost is insane. Especially since the Prius battery seems to be about 1/3 the size (capacity) and 3x the price of the batteries I've put in other cars. They have the same chemistries that are used for other cars, so it bugs me that they're 3x the price.
  8. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    The walmart batteries are quite good, been using them for years in all my vehicles (inc the prius).
    Joe Mc likes this.
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    In addition to radio settings, trip odometers, and some engine performance values (your mpg may decline after reset), if you have the driver side power window Auto feature you will have to reset that also. Instructions are in your owner manual.
  10. Mendel Leisk
    42,289
    The window auto-up may or may not need recalibration. I've purposely disconnected the 12 volt neg (doing brake work) and it was ok after. I did lose trip meters and radio presets, and displays set to default. Also, the next few start ups, the car rev'd up unusually, I think recalipbrating something, maybe throttle response.
    With battery swap I hooked up my jump pack with a special cable, that has cig lighter plug at one end (plugs into my jump pack, and an obd connector at the other end, with just the prongs necessary to supply 12 volt. These cable typically have incicator lights to confirm you've got good connection. Google memory saver cable for that.
    Anyway, when doing battery swap, the one hassle I encountered: the $#&8?! Toyota battery hold-down bracket is absolutiely intolerant of the slightest variation in battery height. My replacement battery (Optima Yellow Top) was maybe 1 mm taller, and I needed to shim the bracket with a washer to compensate.
    DogDaze likes this.
  11. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Thats a good idea Mendel. Would using a regular jump starter turned on and connected to the jump points under the hood also work? I think my jump pack has a cig adapter also, I'll have to check that and the memory saver ODB2 for the next battery replacement.
  12. Mendel Leisk
    42,289
    Yes that should work.
    It’s more convenient; here’s one:
    https://www.napacanada.com/en/p/CLOESA30?cid=paidsearch_shopping_dcoe_google&&&&&gclsrc=aw.ds&gad_source=1&gbraid=0AAAAADl60MScpqYtM0rZyf6lO3pbfmuRh&gclid=Cj0KCQiA-aK8BhCDARIsAL_-H9my7MAu0RP0Xxlr1m9LVYXLJOiNs_g2CvMTu8vCuRrq25Tsm7mz9M4aAt8jEALw_wcB
    I’ve got a couple, one per the above.
    DogDaze likes this.
  13. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Maybe that was my 2008 then. Had to power the window down at least half way, and then when raising it back up continue holding the switch on after the window is closed for a couple seconds. Maybe there was even an ergonomic "click" in the switch when set.
  14. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    I know you will all get a chuckle out of this one..
    My wife's 2011 Liftback is still running with the original OEM battery.
    I do keep in on the trickle during the winters when we are away or don't drive hers for some time. Never an issue, tho I do keep a small starter pack in the back.. (equivalent to a USB start pack, tho have never used it yet)
    Flash forward to last week when we had a small spill in the back that somehow eluded the Weathertech mat... and so I went down below that for clean up.. was nothing more than a paper towel but I pulled everything and even lifted the battery up.. I didn't have to unhook it, but merely removed the tie down bracket and pulled the vent tube so I could lift it high enough.. I just wanted to make sure it was clean below the battery. (it was)
    Yesterday, she came back in the house, said the car started, but wouldn't go into reverse.. I thought odd.. so I went out and it was fine for me... I thought maybe she didn't get her foot on the brake before she pressed the start button.. seemed to be the only thing I could think of.. it was fine for her.. today I went out and the dash was dim.. all the lights were on in a dim glow.. (kinda like my PriusV did when the battery was bad) I turned it back off... waited a few minutes.. and tried it again and it was fine.
    I tend to think that I need to replace that battery... but I hope that is what it is.. Kinda weird.. perhaps since I disturbed it last week, or just coincidence since I mean.. it IS a 15 year old battery I guess... I can't honestly say I've ever had a battery last as long as this one.
  15. Danno5060
    405
    208
    Wyoming
    Since you didn't disconnect the battery, maybe make sure the cables are still tight - especially the connection between the ground cable and the body.
    DogDaze likes this.
  16. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    15y old on original 12V battery is not common , but more than 10y old is not uncommon. Mine and my colleagues original Yuasa AGM lasted more than 10y, and I think his lasted 13 y right after his Hybrid battery also need replacements at 330k miles. He lived in the UK, parked outside, but the weather is relatively mild.
    If we park the car in the garage most of the time, any battery will last much longer
