2011 Prius Battery Reconditioning? - Sitting for 4 years
Discussion in 'Gen 3 Prius Technical Discussion' started by Tusker, Apr 18, 2024.
  1. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    We actually run our Gen2-Gen4 Prius Dischargers down to 84 volts now. We were getting the occasional discharge beyond what the module could handle at 5 volts and we found that you could still increase the capacity by a significant amount though you are only going to 84 volts.
  2. Carall
    Carall Active Member
    306
    102
    Harrisonburg, VA
    Discharging down to 84 volts is effective for batteries that are not very old and worn out.
    I'm testing a single cycle method now. Charge-discharge-charge. I've noticed that after the first deep discharge cycle, the capacity increased significantly and the next 2 cycles did not bring any improvement, charging and discharging took the same time.
    Years ago, I read an article made by someone who described how he completely discharged the entire battery pack to almost 0 volts and recommended to reсondition it that way. I ignored it at that time, because I knew how to do it “the right way”. When the RC chargers couldn't fix my two battery packs, I started researching how to do it a really right way.
    I have heard different stories why you cannot discharge to such a low voltage, but there is no proof in favor of these stories.
    However, I don't think battery packs less than 10 years old should be discharged to such a low voltage.
  3. jeff652
    607
    624
    Idaho
    Hmm, that sounds like it would be worth looking into. Maybe when life slows down a bit for us.
    So when testing the discharge cycles, how far down was the first deep cycle that showed the most capacity increased? Were the next 2 cycles at a lower voltage?
  4. Carall
    306
    102
    Harrisonburg, VA
    This depends on the condition of the battery.
    For the past few years I have always discharged below 84 volts and have also tried discharging down to 5 volts in the first cycle and in 3 cycles. I usually discharge fresh batteries to 40-80 volts. Batteries with over 150k miles and over 10 years old i discharge down to 5 volts.
    I have 3 batteries that I need to recondition on three low mileage Priuses: a 2007 with 68K miles, a 2012 with 102K miles, and a 2013 with 78K miles. I'm thinking about discharging the third generation batteries to 80V and seeing how much the capacity rises.
    2007 battery I'm going to discharge below 20 volts. Although it only has 68k miles, it is 17 years old.
    I've cycled this battery once down to 5.4 volts.
    Tow truck coming in the morning | Page 3 | PriusChat
    I tested 2 modules which I checked before the cycling. The capacity is now 7100mAh, but this is not a good indicator, it should be around 8000mAh.
  5. Tusker
    Tusker New Member
    22
    Missouri
    Ok, so I feel like I need to reassess my approach to this battery. I've run 4 discharge/charge cycles so far, with the discharge to 6.0v and the charge @ 3.0amps to 7500mAh. The discharges have reached an average of around 5600mAh across the board. They seem pretty consistent. I'm currently going through what I thought would be my final discharge/charge cycle, but this time bringing each cell down to 3.0v, according to the advice of Hybrid Automotive above. However, with Carall's advice to bring them to near 0 volts, I'm considering doing another cycle to that level when this one is done.
    @Carall, is there any reason I shouldn't do this?
    #25 Tusker, May 17, 2024
  6. Carall
    306
    102
    Harrisonburg, VA
    All you need to do with this battery is to discharge it as one unit with a low current of 300-500 mAh down to 80 volts and charge it with the same current to a maximum of 239-242 volts, depending on the condition of the battery.
    I didn’t come up with this and it’s not Hybrid Automotive, but this is what scientists say who know what they are talking about and this is confirmed in practice. However, these people did not consider the option that someone would restore 15-year-old or older batteries.
    RC chargers are not capable of discharging and charging with currents below 1A and they cannot balance all modules as one.
    Read here what the nickel-based batteries reconditioning process is.
    http://ni-cd.net/nicddownload/NA_Memory1.pdf
  7. Seymour1
    Seymour1 Member
    266
    32
    I have been using a CQ3 charger to recondition/test my modules. I learned that, according to Battery University,that a fully charged NiMH battery loses 20% capacity in the first 24 hours. So, to get the highest readings, retest immediately after a discharge/charge cycle. My modules have tested better than 5000 mah if I retest without delay. New modules will provide greater than 6500 mah, but I do not know under what conditions.
  8. Tusker
    Tusker New Member
    22
    Missouri
    Hi Seymour, thanks for replying. Would you mind sharing the process you're using to recondition modules? Have you been able to get the charger to detect delta peak? So far, all but one of my charge cycles has ended because the charger reached 7500mAh. As such, charging a battery has taken quite a while, since I can only restart cycles before and after work.
  9. Tusker
    Tusker New Member
    22
    Missouri
    I'm finally ready to put this battery back in the car. I did a 48hr balance and then 2 minute load test for each cell and each one measured either 7.91 or 7.90 volts.
    Still unsure if my procedures were correct, but I'll just go with it for now and see how it works.
    Thanks for your help guys.
  10. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Even lithium Prius packs after being fully charged in the car discharge some after then charger is removed.
    It's good to know what the specs are and it's even more helpful to have some history of the packs to compare results with. Unfortunately there are only so many ways of getting that history data to compare with reconditioning results. At least now you know that you're getting 5ah out of your C3Q charged modules at the point you tested, so you can compare with the next one, if / when that time comes.
  11. raymonty
    raymonty Junior Member
    Dahlonea, GA
