2011 Prius blows headlamps way too often, not HID
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TroyMclure, Mar 30, 2015.
  1. Former Member 68813
    3,524
    983
    US
    i agree, nevertheless, TSB for defective wiring resulting in bulb failure is a fact. BTW, the circuit is more than 12V, its as high as mid 14'sV and maybe even more when just switched on (transients). Maybe the "improved" wiring has more inductance or resistance?
    exactly!
  2. Newsie11
    Newsie11 Junior Member
    CNY
    2014 Prius v wagon
    My 2010 has blown 6 or 7 in 94K miles, I assumed it was bad design and higher than usual vibration that was doing it (I use it a lot for deliveries, going off and on the road to mailboxes).
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Do you also leave the headlight switch in the On position when shutting down/starting car?
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Yes, the transients when converter is turning on/off could be the reason. But more likely to me is low voltage on bulb. Anybody ever measured voltage on running bulb ?
    - Alex
    CR94 likes this.
  5. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    According to earlier posts that detailed the problem, the "improved" wiring has lower resistance.
  6. Former Member 68813
    3,524
    983
    US
    OK, how that prevents the frequent burnouts issue?
  7. mrbigh
    3,686
    699
    Long Island, NY
    Upon reading few posts and the Toyo parts kit, it consists on installing a heavier wire gauge to such headlamps assembly.
    For the vehicle owners out of warranty (36k miles) it's a 3 shop labour hours by Toyo standards .
  8. alekska
    435
    138
    Atl
    Lower resistance = higher current, hotter filament. In turn, that equals to higher brightness. Hotter ( but within specification, unlike too low temperature with faulty wiring) allows halogen cycle to restore the filament by returning evaporated material back to the filament. That should provide the extended life of the bulb. Should be around 1000 hours for standard bulbs, and close to 400 hours for "+30%" or alike bulbs.
    Alex
  9. Former Member 68813
    3,524
    983
    US
    if the defective wiring lowered the filament temp that much, the lights would be visibly dim and yellow. not sure I buy it, but at least it's a possible explanation.
  10. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    In other words, according to the official theory about the halogen cycle, slightly lower than intended voltage reduces life of these bulbs, while with even lower voltage they would be "visibly dim and yellow" but last a long time, typical of ordinary incandescents operated at substantially sub-normal voltage.
