2011 prius burning oil at 82k miles at 1 qt per 3700 miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by shmu, Aug 24, 2022.
  1. shmu
    shmu Junior Member
    cincinnati
    All oil changes done at dealership mostly every 10k miles.
    Mostly city driving and about once a month highway driving.
    This is the first time I am observing the dipstick. I had not looked at it before.
    Last oil change done before 6k miles. Dipstick currently at lower dot.
    So assuming the oil level was at the top dot at the time of last oil change,
    I calculated the rate of oil burn at 1 qt per 3700 miles.
    I just topped off the oil to the top dot with the same oil as it had before
    which is toyota 0w-20.
    The obd tool shows egr flow at about 19.5 kpa consistently.
    So far only oil changes and tire rotations have been done with this car.
    I am not a diy person.
    I researched on this issue on this forum. But considering that this Prius is burning oil at low miles, I felt the solutions would be different, like maybe there is still a chance that a engine flush might fix it?
    Please advice what can be done to best manage this oil burning issue.
    #1 shmu, Aug 24, 2022
  2. PriusII&C
    PriusII&C Active Member
    370
    130
    San Jose, California
    Not sure if your "assuming the oil level was at the top dot at the time of last oil change" is a good assumption. If your OCI is 10,000 miles and the oil burning rate is 1 qt/3700 miles, your car would only have 1.7 qt oil left at last oil change. That is too low, and the tech at the dealership should have warned you. If they didn't, I would not trust that dealership for doing the right work.
    After you fill up the oil, check its level frequently to get an accurate oil burning rate before taking next step.
  3. rjparker
    rjparker Tu Humilde Sirviente
    8,223
    4,879
    Texas Hill Country
    Generally the oil change guys overfill rather than underfill. Some of these cars burned oil excessively before 60,000 miles. Toyota replaced pistons and rings for those cases. It is not high mileage wear per se that causes the issues. It is the oil ring and piston grove design that allows them to stick. The ring sticking causes unrepairable wear on the cylinders. Flush should be professionally done if that is in the cards. Hydrolock and bearing damage could occur. As suggested, watch the level closely. Even more serious wear occurs throughout the engine if you lose oil pressure from a lack of oil.
    MrPete and shmu like this.
    49,811
    start by cleaning the egr circuit before you blow the head gasket, and reduce oil changes to 5k.
    i hope your changing the air and cabin filters, and consider changing the tranny fluid
    V Sport Wagon, Foxglove and shmu like this.
  5. Mendel Leisk
    38,981
    Yeah top it up to upper mark on dipstick, note the miles, continue to monitor. IIRC the diff between the two marks on dipstick is 1.5 liters, 1.6 US quarts.
    mikey_t, ToyXW and shmu like this.
  6. fuzzy1
    10,279
    :eek:
    Occasionally looking at oil level is an essential element of vehicle ownership, of all oil-lubricated vehicles. It is the responsibility of the owner / driver to catch any low oil level before it causes damage.
    That is not excessive, at least according to your Toyota's Owners Manual:
    All of my previous vehicles, of all brands, have said essentially the same thing.
    Not surprisingly, there is a very wide disconnect between what car owners expect, and what car makers will cover on warranty.
    shmu likes this.
  7. Mendel Leisk
    38,981
    The 3rd gen excessive oil consumption criteria was a little less nuts than owners manual, a US quart in 1100~1300 miles. The cut-off is 60k miles though. See attached.
    #7 Mendel Leisk, Aug 25, 2022
    shmu and fuzzy1 like this.
  8. shmu
    shmu Junior Member
    cincinnati
    Gasket-masters will be visiting Cincinnati in the next few days. They quoted me $3650 to replace with a rebuilt engine with all new components and three year unlimited miles warranty. It includes egr system cleaning, new spark plugs and engine coolant.
    He also said my odometer will remain the same and the car title will remain the same. So I guess it should not impact the resale value of the car.
    He said that they have seen many cases as mine and nothing works except for fixing the engine. He also said that this winter many 2011's will show up with head-gasket problems since it will about the same age as the 2010's had the head-gasket issues. And suggested me to get the engine replaced. Please let me know your advice whether I should wait or go ahead with the engine replacement.
  9. nicoj36
    nicoj36 Active Member
    499
    159
    There are folks who got rid of their oil-consumption by using fuel-treatment products. Search Prius under the question box and you’ll see their reviews.
    https://a.co/d/etPJypW
  10. rjparker
    8,223
    4,879
    Texas Hill Country
    Exactly what is being fixed? Bad head gasket? Go rebuilt. The car's value will change. It will go up. Be sure to keep the dicumentation of replaced parts and services performed in the engine. But if it is just oil consumption at one quart every 3700 miles (verified), I would wait for a worse failure.
    #10 rjparker, Sep 9, 2022
    shmu likes this.
  11. Noahdoge
    Noahdoge Active Member
    166
    121
    Mississippi
    Agreed. I think it would be overkill to pay almost $4,000 on an engine that Toyota would state as “normal oil consumption”. OP I would personally switch to 4-5k mile oil changes and just check the oil every week and top off as needed. Save that money for the HV battery or brake booster replacement.
    mikey_t and shmu like this.
  12. shmu
    shmu Junior Member
    cincinnati
    I only have the oil consumption problem at this time. The new engine will have the new piston components and also new head-gasket so that I don't have the head-gasket problem down the line.
  13. bisco
    49,811
    does gasket masters cover the whole country now?
  14. shmu
    shmu Junior Member
    cincinnati
    Cincinnati just happens to be an area they will service the next few days. He could not tell me when will be another time they will be here. I would have to make a request for service and they will fulfill it whenever they have enough customers in the area to make a visit, I guess.
  15. Noahdoge
    166
    121
    Mississippi
    I have a 2012 with 162k miles on it. No head gasket issues. I think you can drive this car years w/o head gasket issues if you change all the fluids regularly and clean EGR system in about 10-20k miles. Your car has such low miles on it I wouldn’t even bother. Just increase the oil change intervals to about 4,000 miles and you’ll be golden. Use that money to pay a legit mechanic to replace engine & inverter coolant. If you feel comfortable with DIY, cleaning the intake manifold EGR ports is super easy.
  16. douglasjre
    douglasjre Senior Member
    1,934
    668
    Null, NL
    Assume nothing
    kc410 and shmu like this.
  17. OptimusPriustus
    OptimusPriustus Active Member
    314
    131
    Finland
    1 qt per 3700 miles. Thats nothing. I would say like the Brits say: Keep calm and carry on:)
    just remember to check the dipstick frequently and add oil when needed.
    shmu likes this.
  18. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    I agree with others about monitoring your oil closely to get a better idea of just how much it's burning. After that I'd get the piston rings cleaned with a piston soak or engine flush just before an oil change and then monitor closely again to see if it's burning less.
  19. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Does any of this apply to 2013 gen 3?
  20. mikey_t
    370
    391
    Los Angeles
    Yes. Toyota made some changes in the engine to 2014-2015 years that may have helped mitigate the issue, prior to that it seems to be very common.
