2011 Prius engine shaking, knocking violently
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jay90, Nov 8, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Cleaners (even name brand) only do so much:cool:.
    Pressure washer will get the job done toot sweet;).
    Good luck and keep us posted (y).
    RMB likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Acetone works good too
  3. Mendel Leisk
    42,352
    I'd prefer a mildy caustic water-based solution to acetone though, any day of the week. Oxi does react with carbon, and slow but sure will bubble it clean. Unlike acetone, you can work in the laundry sink, without stinking up the house, maybe drifting off.
    I do have a can of acetone kicking around. First thing I did when I got it was take the #$@*! plastic security ring (or whatever the heck it's called) off the actual steel cap: if anything it made it more spill-prone.
    Grit and Raytheeagle like this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Think you can use water from the tap under pressure and save the emotional debate:p.
    Give it a shot and you’ll see(y).
    Grit and m.wynn like this.
  5. Mendel Leisk
    42,352
    At the rate I'm piling on the miles (not) there may never be an encore. :rolleyes:
    Grit, m.wynn and Raytheeagle like this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’ll have a dirty one in a couple of weeks you can practice on;).
    Do you have a pressure washer in your tool backlog:whistle:?
    Let us know if you ever want to part with the garage queen(y).
    Grit, JC91006, RMB and 2 others like this.
  7. jbfw
    jbfw New Member
    Indiana
    Just reporting in...the car is running great after the initial startup from cleaning the intake, EGR cooler and valve. The startup consisted of tons of bucking and the engine dying at idle for 2 minutes.
    I then just decided to drive it to work any excess moisture out...and the car has been fine the past 250 miles now.
    The EGR cooler and valve cleaning took care of my bucking issue on startup for now!
    How'd things work for you OP?
    Jay90, Grit, m.wynn and 3 others like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Unfortunately this Isnt still enough data for Bill Norton.
    m.wynn, RMB, mjoo and 1 other person like this.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    We just need more people to report back;).
    But that is a different mountain to climb :cool:.
    Grit, m.wynn and RMB like this.
  10. jbfw
    jbfw New Member
    Indiana
    lol, who is Bill Norton?
    Grit, m.wynn, RMB and 1 other person like this.
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Sorry, not a mountain I care to climb.
    Pixel XL ?
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I try to be as friendly and helpful as possible, hoping a pleasant experience will lead to reports of the outcome;).
    But not always the case:cool:.
    I’m an eternal optimist though(y).
    Grit, m.wynn, RMB and 3 others like this.
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    A member here who says that what you just did was a poor use of your time:cool:.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Knocking came back on mine after 15 months since the first time it happened, knocked about 2 seconds at work on cold soak today. Drove about an hour at 55 mph & was parked it in temps of mid 50s. 7 hours later, knocks from cold soak start up. Never turned engine off ever during ICE warm up under my ownership. Can't wait to put poor use of time to it (y)
    RMB, m.wynn and Raytheeagle like this.
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    And just think others are willing to help use their time to help you “waste” yours:rolleyes:.
    The end of the month is looking better since the wife’s business trip is getting postponed (y).
    RMB, Grit and m.wynn like this.
  16. JC91006
    16,936
    8,647
    Doesn't Toyota have a TSB for this issue? Last I read, they change the intake manifold, but that may be different now
    RMB likes this.
  17. Mendel Leisk
    42,352
    I think the intake manifold revision changes the EGR, from:
    One large passage that feeds into four narrow.
    To:
    One large passage that feeds into two intermediate that (both) feed into two narrow.
    Somewhat speculative, did see some pics though.
    I've also read that it didn't make that much difference.
    RMB, JC91006 and Raytheeagle like this.
  18. Jay90
    Jay90 New Member
    Detroit MI
    Hey did you install oil catch cana nd cleaned Egr ? did it make any difference ?
  19. Jay90
    Jay90 New Member
    Detroit MI
    UPDATE :
    i used a snake oil called Rislone engine repair to see it works, it made some difference. Here is the situation now:
    that vibration and shaking has reduced to half or even more, check engine only comes in flashing when i am taking off from cold start. once i exceed speed of 30mph there is no more shaking or vibration nor any check engine light, i drove about 35 miles 95% on freeway yesterday, check engine light came on when i started driving then no more check engine light, however if i let go of the gas pedal and repress it , it makes some vibration around similar rpm but as rpm increase vibration disipate. how can higher RPM cause engine to run fine ? What do you all think ?
