2011 prius engine won't start but will move in EV for a bit
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andy song, Jan 12, 2022.
  1. andy song
    andy song Junior Member
    Hi all
    I have a 2011 prius that my niece was driving one day and died and won't start
    She is young and could not remember anything out of the ordinary when the car stopped running
    The car says check hybrid system so we had a new HV pack installed
    The car would go into Ready mode and we can drive it in forward and Reverse but the ICE never came on. After a few seconds the ready light will drop and the check engine light came on and we scanned the code for misfire in cylinder 1 2 4 and 5 as well as the crank position sensor
    We replaced all the coil packs and a new crank position sensor. All OEM parts
    We can start the car and we noticed the pulley never moves (the pulley that is connected to the crankshaft which is bybthe passenger wheel)
    We took it to a local Toyota dealer and they said we need a new transmission which they quoted $4800
    Car has 288k so it is not worth the repair cost
    We have a feeling they might just think we are suckers and will pay them
    Hoping to ask the gurus here if it might be something simple
    I read that if the car drives in reverse then the electric motor is working which elimates the transmission being bad
    Any help would be appreciated
  2. JC91006
    16,936
    8,646
    is it out of gas?
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Blown motor not tranny
    52,804
    sell it for parts, or call eric becky in madison
  5. ChapmanF
    18,980
    That's a very expensive way to proceed when the hybrid system includes so much more than the battery and "check hybrid system" can mean so many things to check.
    At this point that's now a sunk cost, but you can avoid incurring more such costs by making sure you get the trouble codes that indicate what issue the car is reporting. You can post those codes here and then more specific advice will be possible.
  6. andy song
    It has over half a tank
  7. andy song
    If the motor is blown when we start the car the pulley connected to the crankshaft should still spin. There is no movement of the crankshaft when the cat goes into Ready mode
  8. ChapmanF
    18,980
    Can you post a video or audio recording of any sounds as the car is going ready, and in the following 20 seconds or so?
  9. tankyuong
    1,555
    662
    Central MO
    Motor locked up so pulley wont spin
