2011 Prius Four: "P" (park indicator on dash) in a frame?
Discussion in 'Gen 3 Prius Main Forum' started by Synthetic, Jun 12, 2017.
  1. Synthetic
    Synthetic Junior Member
    35
    El Paso
    New to us is a second Prius. This is a 2011 Four. The car performs fine. I see that the "P" for the Park indicator shown on the dash display has a frame around it in normal operation in Reverse and Drive. The P becomes backfilled as do the other positions when selected. But, why the frame when it is not selected?
    Is this normal? Our 2012 v Five does not frame the P.
    Thanks
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Normal as far as I can tell. Mine does it. The bracket stays around the P while the highlight (backfilled) moves depending on shift lever position.
  3. Synthetic
    35
    El Paso
    Thanks. I had our 2012 v to compare with the P-frame and they did not compare. The manual was silent on the issue. Glad to know this is normal.
