2011 Prius front end seems low with a small clearance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vvjap, Sep 4, 2013.
  1. vvjap
    vvjap Junior Member
    ohio
    Has anyone had trouble scraping the bottom of their car entering driveways or shopping centers with entrances that slope up. Even when properly turning the wheels so as not to back out of a driveway straight I have on several occasions in the past year scraped the bottom front of the car. A minor scrap on the engine compartment splash cover does not bother me. Nor does scraping the bottom of the front splash guards. But last week I had to turn around in someone's driveway which did not appear to be a problem. Entering was not a problem but as I backed out I was careful to turn back out on an angle but still managed to hid the bottom of the front bumper on the driver side. Of course it left a small scrape and took the paint off. It's only slightly visible from the front edge as it is underneath the bumper where it wraps underneath. It's annoying but the front bumper of the 2011 prius does seem relatively low in comparison. Now I'm thinking about touching this up, having it spot painted professionally, or applying some flat protective applique along the bottom front edge of the front bumper if there is such a thing. Everyone seems to be worried about the rear bumper protection.
  2. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Others have mentioned it before, but to be quite honest it hasn't been much of an issue for me. I think it may come from what you were used to driving prior. My prior car was an Integra that had about 2-3" of clearance and would scrape on everything even if driven carefully. My wife's Odyssey has never scraped anything. I find my Prius (now lowered ~1.75") has scraped a few times if I'm not careful. Prior to lowering I didn't have any issue.
    I don't think any vinyl protection would help your lower bumper much. You would have to form some metal to protect it the best as the vinyl will shred pretty quick.
    52,902
    helps with aerodynamics, but can be problematic in certain situations.
  4. hlunde
    hlunde Member
    419
    75
    I've had the same problem. Once, driving in the dark and not being able to see an unevenness in a driveway apron. I fractured the plastic panel that is installed horizontally just behind the bumper. Parts cost to repair was about $180. It's really an approach angle issue. I believe that the most recent Matrix has the same issue.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    All those folks lowering their Prius must live on the Bonneville salt flats, no where else would be smooth enough.
  6. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I came out to my driveway a few weeks ago, and saw that the bumper had a tear on the driver's side. I couldn't remember any way I could have done it. So I took the car to my body shop. They said that I was doubtless a victim of the low concrete blocks placed at the front of parking spaces in 7 & 11 and similar establishments. Since the car has low clearance, the block rips the bumper as the driver backs up. They said this is not unique to Pruii; any low front clearance car has the same problem.
  7. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    It's a low car.
    Just adjust. Take steep driveways at an angle.
    If you can parallel park without scraping your wheels, you can get through almost any driveway without scraping.
