2011 Prius going into accessory mode
Discussion in 'Gen 3 Prius Main Forum' started by Lkmckin, Apr 25, 2022.
  1. Lkmckin
    Lkmckin New Member
    Los Angeles
    My 2011 Prius, which I have owned since new, has recently not been booting up properly. Instead, it has been going into accessory mode even when the brakes are depressed. Usually I can get it back into normal mode by turning off the power and trying again, 1-4 times so far. Of course I am afraid that the failure will become permanent.
    Scanning for codes with my scanner gives “no codes “. When the car eventually goes into normal mode, I have gotten a “hybrid system overheat” box for a few seconds. Since this problem usually happens after the car has been sitting for >12 hrs, that message seems like a red herring.
    Any ideas about what could be the problem here?
  2. JC91006
    16,936
    8,647
    Have you checked the 12v battery?
  3. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Do the brake lights come on when you press the pedal?
  4. Lkmckin
    Lkmckin New Member
    Los Angeles
    Good ideas.
    Brake light does come on when brake pedal is depressed. Of course, the failure is intermittent so that might not be definitive.
    12V battery reads 11.1 V. Seems low to me. I will likely go get a new battery and try that.
  5. Mendel Leisk
    42,352
    Yeah very low; how old is it?
  6. bisco
    52,861
    some have reported pressing the go button too soon while applying brake, when in a hurry
  7. Lkmckin
    Lkmckin New Member
    Los Angeles
    The battery is years old. 4-6, I don't recall. But old enough that replacing it is almost certainly the place to start given the low voltage.
    We've owned the car since it was new. I thought the same about not depressing the brake properly when it first happened to my wife. Then it happened to me, and it took 5 attempts to get it into normal mode after shutting down the accessory mode. Not normal behavior for sure.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There is a button type switch that is behind the brake pedal assembly. As you step and hold the brake down, the button is pressed down and the car will go into ready mode. A few have said the button assembly becomes loose over time and readjusting the button switch back into place resolved the issue.
  9. phensolo
    phensolo New Member
    The Peninsula, CA
    Had the same issue. Check the battery and check for phantom electrical drain if the battery is less than 5-7 years old.
  10. Lkmckin
    Lkmckin New Member
    Los Angeles
    Replaced the 12V battery, and the issue seems to have been corrected.
    Thanks for the advice.
