2011 Prius has trouble getting 'Ready' Symbol
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius2010owner, Jan 14, 2020.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    1) A post with a quote usually stands on it's own.
    Adding a comment about something NOT in the quote is just confusing.
    2) Post #8 seems to have disappeared, which likely is what you are referring to.
    Maybe you should "scroll back" yourself.
    Despite some opinions to the contrary, I am NOT in the habit of making posts just to stir up trouble.
  2. ChapmanF
    18,978
    You mean the post #8 from bisco at 5:16pm last Friday, asking "how many miles on her?" That post #8?
    You haven't by any chance plonked bisco, have you? That could explain you not seeing the post. That's one downside of the ignore file, right? You might like some things about not seeing posts from a particular user, but it's still kind of on you if you then post complaints about stuff you didn't see.
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes. But only as a reminder that I should NOT reply to most of his posts.
    The system usually tells me that there is a post there that it is not showing me; not in this case.
  4. ChapmanF
    18,978
    Hmm, I don't know. It seems to be as there as any other post I could think of.
  5. Prius2010owner
    Prius2010owner Junior Member
    23
    LA
    I think the fact that any of you block anyone else is really childish and you need to grow the F up.
    After I replace the battery how long should I wait before I can start my car?
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I never block anyone in traffic, well maybe when parked at our meet ups.
    .32 seconds, no sooner no later.
    #26 Grit, Jan 22, 2020
  7. Prius2010owner
    23
    LA
    Autozone claimed it takes about 1 hour before the car will start....
    Because After installing the battery, the car isn't starting. All the lights will come up, but it won't actually give me the ready symbol yet.
  8. bisco
    52,804
    has it been an hour? sometimes, you have to push the go button several times after disconnecting the battery.
    other than that, it should start right up. not sure why autozone would say that.
    #28 bisco, Jan 22, 2020
  9. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    OP, Please let us know if the new battery fixed this issue.
    The similar happened to my friend's 2010 the other day and I didn't understand if there was something wrong or I wasn't doing it right. But I can tell it happened a few times.
    I will check with him to see if it is still happening.
  10. ChapmanF
    18,978
    I can tell the expiration date on my 12 v battery has arrived: I've had to use my booster pack every morning this week. :)
    Actually bought the replacement battery on Monday, brought it inside to charge, just haven't put it in the car yet.
    Every morning when I have to boost the car, it may take a couple button pushes to get to ready. It usually wakes up thinking there's a parking actuator problem, which it decides is ok again after I shift to N and back to P. Twice, the MID has been dark all the way to work, but is back to working again on my drive home. Just quickly powering off and back on again does not make the MID reappear, only sitting powered off for a longer time. (I think it has a time-delay-off built in, the way it normally continues to show the clock for a while after turning off the car. Probably it doesn't really reboot unless it is off longer than that.)
    But there has never been any particular delay between when I first provide power and when I can go to ready.
  11. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Puzzling why the MID would be dark while driving - after you get to ready, wouldn't the traction battery lift the voltage system even if the 12v is bad?
    More importantly, what happened to Bisco, anyway . . .
  12. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Oh, I see, never mind . . .
  13. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Didn't mean to start any rumors!
  14. ChapmanF
    18,978
    That's exactly what happens; voltage goes to 14.7 as soon as the DC/DC converter comes on line.
    It's pretty clear that the MID is just getting wedged during the sub-seven-volt spell when I'm trying to start without the booster pack (you'd think by Wednesday I would just be hooking it up first thing, right, but no, I always have to try without it first), and it doesn't really reboot until the car is quite off, including on the time-delayed circuit that powers the MID.
  15. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Trust the wisdom of the forum... It's the 12V battery
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    I don't understand the question.
    Why would you think you need to "wait" any time at all ??
    (I see now. See next post.)
    As for "blocking".......I also think that calling others "childish" is not appropriate........and having options to deal with that is good.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    This means one of two things:
    They installed a battery that is NOT fully charged.
    OR
    Your car has serious problems in addition to having had a dead battery.
    There is no "wait time" involved.
  18. Prius2010owner
    23
    LA
    just wanted to check back in and say, Car turned on eventually and the car runs like a champ, brand new.
    Raytheeagle likes this.
