2011 Prius Head Gasket Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Feb 28, 2019.
  1. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    It has the large o-ring that stays on the block, but you might want to get an OE one as the one it comes with doesn't like to stay in the block. The other ones can usually be reused and are not a big problem if they fail.
  2. Avi's Advanced Automotive
    776
    363
    Some pop and some don't. I never really paid attention to which ones do and which ones don't. All I know is I don't remember ever felling one was loose. I did have one break off inside the block. That was fun.
    I've never had problems with the threads in the block, so I doubt you do.
    Robert Holt and The Critic like this.
  3. Mendel Leisk
    42,257
    I think I've got this right, but don't take it to the bank without another read over:
    BECK/ARNLEY GASKET KIT 0323038
    OE Number Description QTY
    11115-37051 GAKSET, CYLINDER HEAD 1
    17173-37010 GASKET, EXHAUST MANIFOLD 1
    17177-37030-A GASKET, INTAKE MANIFOLD 1
    11123-37041 GASKET, VALVE ROCKER COVER 1
    96721-24015 O-RING, OIL STRAINER 2
    96721-19010 O-RING, OIL LEVEL GAUGE 1
    96723-24020 O-RING 1
    90301-07037 O-RING, FUEL INJECTOR 4
    90913-02101 GASKET, SET 8
    90913-02111 SEAL, VALVE STEM 8
    11159-37010 SEAL, BEARING CAP SIDE 1
    11193-37020 GASKET, PLUG TUBE 4
    13552-37010 GASKET, CHAIN TENSIONER 1
    16258-37010 WASHER 1
    23291-73010 INSULATOR, INJECTION 4
    90210-06013 WASHER, VALVE COVER BOLT 1
    90430-12031 GASKET, OIL PAN DRAIN PLUG 1
    90430-35001 GASKET, OIL FILLER CAP 1
    22271-37010 GASKET, THROTTLE BODY 1
    gggGary and SFO like this.
  4. Caballo Prieto Azabache
    Caballo Prieto Azabache Junior Member
    Avi how much do you charge at your shop for this repair? My 2012 Prius at 170k miles has now also developed the head gasket failure.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
  6. Caballo Prieto Azabache
    I called Avi, fair price including parts and labor (he replaces the water pump as well).
    I believe I will be taking a stab at it, I have most of the necessary tools.
    Critic, thanks for the parts/cost breakdown and all the tips. I was looking forward to seeing some of the attachments you posted, however, the links are not working (at least not for me; for attachment 166855 I receive an error indicating that the attachment could not be found ).
    Mendel, thanks for the video and repair manual attachments, I am taking notes.
    Avi, thanks for the heads up on the water pump, I ordered an AINSI from Japan off ebay.
  7. The Critic
    3,193
    2,333
    CA
    Which attachments are you looking for?
    Raytheeagle likes this.
  8. Caballo Prieto Azabache
    It looks great, and the machine shop seems to be fast! How long did they take? By looking at the time stamps, was it only one day?
  9. Caballo Prieto Azabache
    Critic, did you use the two FIPG tubes? I'm debating whether purchasing one or two.
    Thanks,
  10. The Critic
    3,193
    2,333
    CA
    They originally estimated two business days but their other jobs were on hold due to parts being on order. So they had my cylinder head completed same day.
  11. The Critic
    3,193
    2,333
    CA
    My tube dispenser tool broke the first tube so I had to use both tubes.
    One tube is probably enough but it does not hurt to have a second one on hand.
  12. Mendel Leisk
    42,257
    I'm curious: you didn't remove the engine? Assuming no, you applied the FIPG to the cover not the engine? From start of application to install, where you under +3 minutes* (from commence of FIPG gasket)? And then install and torque the myriad bolts by +15 minutes*? I would assume you did the applications of FIPG at the engine seams on those seams, not on the cover?
    I guess long story short, what were your impressions, the Repair Manual instruction vs realities of the the cover install?
    * Repair Manual stipulation, maybe a little nuts?
    The Critic likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    You need a second set of hands on the guide pins ;).
    Through the tire well and works well(y).
    The Critic and Mendel Leisk like this.
  14. Mendel Leisk
    42,257
    Yeah that's how they worked in that video.
  15. The Critic
    3,193
    2,333
    CA
    The engine was not removed for the Head Gasket repair.
    FIPG 103 was applied to the cover. FIPG 103 was also applied to the engine on the six seams. No, I did not use the coolant-specific FIPG on the coolant contact areas - I do not know any tech that does. I also did not measure the thickness of the FIPG beads but from experience, I applied an adequate to slightly excessive amount based on the size of the sealing area.
    It probably took me around 5 minutes to get the FIPG applied and the cover seated onto the engine. From experience, FIPG is not super sensitive in this area. I had the bolts snugged up within several minutes after that point, but I did leave out the bolts for the water pump and the engine mount until 10-15 minutes afterwards. Even without the water pump and engine mount installed, there are enough bolts on the timing cover to maintain pressure on the sealing surface. The important part is to have both surfaces 100% clean, oil-free and to not disturb the BEAD of FIPG when mating the cover to the engine.
    Doing the repair with the engine removed is probably ideal but it wasn't worth the extra time to me.
  16. The Critic
    3,193
    2,333
    CA
    Not sure what happened to the original pictures, but I think these were the ones that were posted.
  17. jack black
    jack black Active Member
    225
    142
    I
    Hi The Critic,
    i'm a big fan of your posts here and on BITOG. Strong work on this! it sucks to know the HG problem can happen despite the extensive maintenance you did. is this also an issue in corolla cars with similar engines?
    Raytheeagle and The Critic like this.
  18. The Critic
    3,193
    2,333
    CA
    Thanks. If you look over on Toyotanation, there are reports of HG failures on the corolla as well. But it is not as common, but perhaps the corolla section does not have the same user base as this forum. In my conversations with technicians, the HG issue affects corollas as well.
    Raytheeagle and jack black like this.
  19. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The 2zr-fe engine (Corolla) has no external cooled EGR. It's internal.
    Pixel XL ?
    #79 mjoo, Apr 16, 2019
  20. jack black
    225
    142
    I
    it has a HG though.
