2011 Prius Head Gasket Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Feb 28, 2019.
  1. Mendel Leisk
    42,355
    @mjoo did a flow experiment with his. IIRC, pouring a measured amount of water through one end, timing how long it took to get through. That'd be a good before-and-after test for everyone doing a cleaning, I think. Doubly so if they post the results here, and the miles they were at.
    Water flow differences maybe don't equate to air flow, but it's at least a benchmark we can do.
    SFO and mjoo like this.
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Water flow (I used a garden hose) IMHO would better approximate the restriction of exhaust gas recirculation at typical engine operating speed. I.e. at 2500 RPM, the EGR circuit flows 1.9 x 2500 x 0.20 L/m = 950 L/m or approximately 16 liters of air per second. This is through a 1-2" diameter pipe.
    After completing several oxi-clean soaks until the cooler was spotless I was surprised by the large drop in restriction. This was compared to just drilling out the fins with a copper wire and using carb cleaner.
    #102 mjoo, Apr 30, 2019
    SFO, CR94, Raytheeagle and 1 other person like this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Not only that, but oil clogging up the cooler is going to reduce its cooling ability.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Any update on your repair?
    SFO and Raytheeagle like this.
  5. ChapmanF
    19,038
    Because the weather was nice over the weekend and I'm at around 143,000 right now, I was looking for a way to judge how worried I should be about the EGR system at this point.
    I noticed that Techstream has an "EGR valve step" active test, where you can tell it to open the EGR valve in tiny steps numbered 0 to 110. At idle, I found that just setting mine to step 14 or 15 was enough to very noticeably roughen the idle, and 17 (out of 110) would just about kill the engine.
    So at least I'm confident my EGR passages aren't completely blocked. I'm curious what the corresponding results are for people who have just completed a spotless Oxi-cleaning.
    Bill Norton, SFO, mjoo and 1 other person like this.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Since I am around 12000 miles post cleaning/engine install, i will check mine out tomorrow and post the result. Maybe that will provide an insight that can help the cause.
    Raytheeagle likes this.
  7. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    At 145k miles mine was completely clogged. I sprayed brake cleaner into one end and nothing came out the other. Granted, I bought it with that many miles and the original owner was in Arizona where it gets much warmer. I know nothing of how it was previously driven and from what I've read here, I believe that pushing the engine with aggressive driving or a lead foot contributes more to the carbon build up.
    It's fairly quick and easy to remove the EGR pipe. I would check that out and observe the amount of carbon build up there. If it's thick then your EGR cooler has a ton more.
    CR94, Raytheeagle and Mendel Leisk like this.
  8. qettyz
    qettyz Active Member
    181
    208
    Finland
    Thats very easy way to test if its completely blocked. Nice to know!
  9. The Critic
    3,193
    2,333
    CA
    If anything, hard driving should reduce carbon buildup. Hard driving equates to higher temperatures which should allow the carbon to burn off.
  10. Mendel Leisk
    42,355
    I'm sceptical, think EGR clogging is as inevitable as death and taxes. Not a fan of Italian tune up lol.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    My version of Techstreeam will not run the EGR test. Fatal error. So looks like someone else will have to do it.
  12. JohnnyJavelin
    JohnnyJavelin Junior Member
    Maybe? Definitely !!
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Which versions of Techstream have the EGR valve step test?
    #113 mjoo, May 1, 2019
  14. ChapmanF
    19,038
    Well, 10.10.018 does for sure.
    I was connected over a Tactrix Openport 2.0 dongle. I also have a Mini VCI dongle, but it messes up more often talking to my Gen 3.
    mjoo likes this.
  15. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    The cooler is too cool for that to happen in it.
  16. mikey_t
    371
    391
    Los Angeles
    Would pushing the engine at higher RPMs not release more of the carbon and oil mix that builds up in the EGR?
  17. Rebound
    3,996
    2,645
    Portland, OR
    It may, but deposits are going to build up over time no matter what.
  18. Mendel Leisk
    42,355
    The EGR cooler is a backwater. A tiny valve regulates flow; I don't think it matters what rpm or load conditions are happening.
  19. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Until contradicted by someone more knowledgeable, I assume there will be a higher proportion of carbon gunk in the exhaust when we push the engine toward max torque, therefore richer fuel-air ratio. Right?
  20. jack black
    jack black Active Member
    225
    142
    I
    generally, in fuel injected cars with oxygen sensor, the fuel-air ratio is kept constant, except for fuel enrichment at WOT. however, i was told it doesn't apply in prius, where redline and max power are reduced.
    mjoo likes this.
