2011 Prius Headlight Issues - Customer Support Program Notification
Discussion in 'Gen 3 Prius Technical Discussion' started by Fearless Flyer, Jan 9, 2018.
  1. Fearless Flyer
    Fearless Flyer Junior Member
    Syracuse, NY
    We just got a "Customer Support Program Notification" in the mail yesterday regarding halogen headlamp time being shorter than expected.
    Toyota is offering to replace BOTH Low beam harnesses and bulbs(both sides) if you have a low beam that goes out, good through 10/31/2019. In addition, they will reimburse any costs incurred if you replaced a bulb yourself prior to receiving this communication.
    I got the notice yesterday and my driver-side low beam went out the very same evening(what are the chances of that?). In addition, we had the same issue on the right side this past November(2017).
    Promptly called my local dealer and brought it right in only to find they don't have new bulb/harness required and gave me a free loaner vehicle until parts come in since it's a safety/liability issue.
    So, 2010-2011 Prii owners, watch for this mail from Toyota!!
    Tideland Prius and Danny3xd like this.
    52,854
    my low beam went out on my 2012.:(
  3. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    Thanks for posting, FF.
    #3 Danny3xd, Jan 9, 2018
  4. Tande
    Tande Active Member
    556
    339
    Mich.
    Which trim/levels had the halogen headlamps?? .......
  5. CR94
    CR94 Senior Member
    2,830
    1,242
    Northwestern S.C.
    Got that.notice in November. No bulbs have failed in the 43k miles I've owned my 2011.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    My drivers-side low beam bulb failed November 4, 2018. First and only failure since I purchased the car used. I replaced both bulbs with Philips H11 X-tremeVision bulbs. Philips bulbs are OEM, but this model is tweaked a bit for brightness. Nice improvement in road illumination. Then I think in December I get the Customer Support Program Notification. So, first week in January I schedule my 160,000 service and mention the bulb failure and the notice I received. Service writer looks it up and we discuss options. I don't think a headlight bulb burning out at 150K+ and almost 8 years of service would be "too soon". But I did say I was interested in the replacement wiring harness which is supposed to lower the voltage to the bulbs below the ~14V they are currently seeing. I hope I don't lose too much brightness because of this. We will see.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :eek:
  8. Tideland Prius
    16,680
    II/Two, III/Three and IV/Four (as well as the I/One for fleet vehicles).
  9. Danny3xd
    238
    149
    CT. U.S.
    Sorta related but not terribly on topic. Replaced driver's side headlight bulb. Gotta say I was dreading it after the NASA like effort it took changing bulbs in the gen 2 over this '10, gen 3.
    Really easy. Didn't need a vid, manual and Empire State litigator to translate instructions.
  10. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Replace bulbs in pairs, not just the one that fails. Keep the old bulb for a backup.
    ITBland likes this.
  11. Danny3xd
    238
    149
    CT. U.S.
    I must humbly beg to differ, Xlid. Though I most always buy 2 of such. Probably my penchant to not waste anything. As easy as this was to change. Easy roadside repair if needed.
    But again, don't mean to be contrary, just my approach.
    Ya know, cheap. LoL.
  12. xliderider
    8,140
    3,280
    Honolulu, HI
    Bulbs dim over time, replacing them in pairs will give you two bright bulbs.
    ITBland likes this.
  13. Danny3xd
    238
    149
    CT. U.S.
    Think most folks would agree with you and follow your advice, Xlide.
  14. Tande
    Tande Active Member
    556
    339
    Mich.
    Thank You.......
  15. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Whoops, you all know what I meant.
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    On the way to work last night my passenger side low beam failed. That is a little over 3 months of service since I replaced both bulbs 11/04/17. A couple weeks ago I installed a smart car USB charger in the 12V auxiliary socket (refuse to call it a cigarette lighter socket) which provides two USB outlets and displays the battery voltage in whole and tenths of a volt. This might not be the voltage that the headlights are seeing, or maybe it is. It's pretty hot, displaying between 14.6 and 14.8 volts while driving. This got me to thinking. My 12V aux battery is still original, probably going on 8 years. I might pull the battery this weekend and find the date stamp. I periodically use a battery conditioner which might be extending the life of this battery, but sooner or later it will fail to hold a charge. I figure this might be happening now, hence the higher voltage I am seeing which might be causing or adding to early headlight failure. I probably don't notice the telltale sign of lower MPG since I spend all my driving time at interstate speeds. I know there is this Customer Support Notification Program concerning headlight failure, and I have the replacement wiring harness on order with my dealer, but now I'm wondering if a replacement battery might be a good idea too. I watch the voltage display when starting and there is a quick drop to 11.9V as it is making READY. Thoughts?
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I'm scheduled for the headlight wiring harness replacement this Saturday. Service writer says it's a 5 hour job. Sounds like they will have to remove the front bumper. I'm still wondering about what I discussed ^above^ concerning DC-DC inverter voltage level that may be higher than normal in an attempt to charge a near-depleted 12V battery, and in turn affecting the health and longevity of headlight bulbs. And who knows what else. Can anyone comment on a typical running voltage that they have seen? I am observing a consistent level between 14.6 and 14.8 volts, which I think is a little "hot".
  18. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    And so, wiring harness and low beam bulb replaced on both sides at my dealer. It was a six hour job. Lights are working fine. In a related matter, something I had discussed above, I had my 12V on my conditioner this morning and the retention test came up red. My 8 year old OEM battery was ready to retire. With all the options available, and considered, it is really hard to get a better deal than the Toyota Truestart battery. Seven year warranty (2 years direct replacement, 5 years pro-rated). Replacement took about 20 minutes. Done deal, and reliability restored.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If your brave enough, put a multimeter to the low beam harness and measure the voltage. Since 14v was blowing out bulbs, they probably lowered the voltage down.
    Just carious to what voltage the recall has it now.
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I was wondering that too. Not an easy task though. Tight quarters on both sides and the measurement would have to be made across the terminals with the bulb plugged in. Waterproof plug if I remember correctly. I'll see what I can do. My monitoring of running voltage hasn't changed with the replacement of the 12V battery, so my suspicion of higher voltage being produced to "charge" a failing battery doesn't seem to hold water.
