2011 Prius - Headlight Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JohnH0615, Mar 14, 2016.
Tags:
  1. JohnH0615
    JohnH0615 Junior Member
    Brunswick, Ohio
    I own a 2011 Prius TWO. A few days ago, one of my headlights went out, so I replaced both (figuring that if one went out, the other could well be close behind). It seemed like a pretty straightforward job at the time.
    However ... the new lights are very dim, almost to the point where I wouldn't want to be driving in the dark. They seem to both be seated correctly, and they are emitting light -- just not nearly enough. I used the H11 bulbs that (I thought) were the right specification -- but is there anything that I am missing?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    need to adjust them
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Sounds like they are not mounted correctly, most likely at an angle. The driver's side should be easy to access, the passenger side, remove the 10 mm bolt holding the air intake hose and release the adjacent bracket further up the intake and bend the intake hose up and out of the way.
    Be careful you don't leave the bulbs mounted crooked in the headlight housing or you risk melting the plastic mounting surfaces. That would be very expensive, as you would need to replace the entire headlight assembly.
    sprtent likes this.
