2011 Prius hit. Air bag did not deploy
Discussion in 'Gen 3 Prius Main Forum' started by PriusTransduced, Oct 18, 2020.
  1. PriusTransduced
    PriusTransduced New Member
    First, I am new to the chat, but have many of you to thank. Over the years, I have sought info and this site always been a great resource. Thank you to all who help make the community!
    My 2011 Prius, that, at almost 300,000 miles has been amazing, was slammed into as I was waiting to turn. The front driver's side was hit at an angle, underneath the headlight. The other driver was across from me, turning in the opposite direction, so she went from a stop to excelling, attempting to cross 2 lanes as she hit me. The impact also popped the bumper off the passenger side. I was amazed at how well the car held up, but have concerns about the airbag not deploying. My head hit the side and I have a concussion. I felt the force. The other driver lied and said I hit her. The police said they will leave it up to the insurance companies to figure it out. My car will be towed to a Toyota collision center, my concerns are listed below. Any input would be much appreciated.
    1. From looking at the placement of air bag sensors, it looks like a sensor is located where the car was hit, yet It did not deploy. Does this seem right? Does a car have to be moving?
    2. I had the recalled Airbag brackets installed. Could this be connected?
    3. If there a way that the computer system in the car can show that I was not moving? If so, how would the information be obtained? When I asked the adjuster, she said "they would not look at the black box."
    4. If there is damage to the hybrid system, would it show when they run codes? or is a separate diagnostic test needed?
    5. Somewhere in my reading, I read that Toyota had some problems with cars in high humidity. Does anyone have any info about this?
    6. What else do I need to know about what to have checked, and the collision center/ body shop process?
    Thanks in advance!
  2. PriusTransduced
    Heres are pictures.
  3. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    It maybe a problem with the airbags, they recalled the ones that replaced the defective ones, so the new ones are defective as well, they are even saying that seatbelts may be recalled as well, i would contact toyota and see what could you find out you may have a lawsuit against toyota if you got injured.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    The car doesn’t have to be moving, or even turned on, for airbags to deploy; see this video of a NHTSA side-impact crash test on a 2010 Prius, in which the car itself is stationary. You’ll also notice, however, that the impact from the test sled is quite severe, and the damage is much worse than that to your car.
    Airbags aren’t meant to deploy in all collisions. As Toyota explains in the Owner’s Manual (PDF), on page 121, “The SRS side airbag and curtain shield airbag system may not activate if the vehicle is subjected to a collision from the side at certain angles, or a collision to the side of the vehicle body other than the passenger compartment.”
    Deploying airbags can startle or injure the driver or passengers, so the supplemental restraint system (SRS) is designed to deploy some or all of the airbags only when its sensors have detected a collision in which they’re likely to do more good than harm.
    Unless the repair was done improperly, no. The Technical Instructions for Safety Recall G0U (PDF) describe that repair, in which the airbags themselves shouldn’t have been removed or disconnected, even temporarily. Rather, brackets were added to keep pieces of the side airbag inflators from entering the cabin, if one were to crack open spontaneously. Nothing in the repair should have changed whether or not the airbags deploy.
    This information might well be stored in the car’s event data recorder, described in the Owner’s Manual, pages 504–505. See also my March 2019 posting about Toyota’s EDRs.
    An investigator would connect a crash data retrieval tool to the car.
    That’s unfortunate. With liability in question, an adjuster’s out-of-hand refusal to gather potentially relevant information would seem to raise a question of bad faith by the insurance company, which usually has a duty to properly investigate claims.
    Especially if you were injured, you may wish to consult a lawyer, before repairs are made or evidence that might be gathered from the car is spoiled. With lawyers who take personal injury cases on a contingency fee, there’s typically no cost or obligation for an initial consultation.
    If the repair shop uses the Health Check feature of a Toyota Techstream diagnostic system to scan for diagnostic trouble codes (DTCs)—as Toyota recommends in Collision Repair Information Bulletin 2016-191, “Scanning for Electrical System Faults” (PDF)—this would cover the hybrid system. It would also help establish whether the SRS was in working order at the time of the collision.
    Of course, the car might have been damaged in a way that wouldn’t cause a DTC to be stored until after the car has been driven a while, or at all, so there’s no substitute for a thorough inspection.
    You’re probably thinking of the situation with other vehicles having the infamous airbags made by Takata, which have an unfortunate tendency to deteriorate, causing the airbag to produce shrapnel if deployed. Heat and humidity accelerate this deterioration.
    Pluggo and PriusTransduced like this.
  5. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    The car will deploy air bags depending on impact location onto your car exterior, passengers seated location, speed, and etc to protect and not kill you.
