2011 Prius IV - before I buy?
Discussion in 'Gen 3 Prius Main Forum' started by AltraStache, Dec 6, 2019.
  1. bisco
    52,888
    we only know what is reported here. there is no data regarding percentage or quantity of vehicles affected.
    this is where you come when your egr is clogged, you have a misfire, your head gasket blew.
    very few join here to tell us their egr is clean
    AltraStache likes this.
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    I believe for every bad one you hear about here, there are thousands out there that nothing happened to...I see so many for sale with 200k+ miles and report they've pretty much just kept the oil changed, maybe brake pads, and regular scheduled maintenance.
  3. Summerboy1958
    Summerboy1958 New Member
    Delaware
    Thanks. The squeaky wheel. Any idea if that is included in a cpo inspection?
  4. Summerboy1958
    Delaware
    Also, what are the symptoms? The misfire or cylinder slap noise like is some others that have valves coked up from the egr return to intake manifold?
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There's the inverter failure that all prius gen 3 will eventually die off due to over heating, the TSB doesn't fix it either and the momentary loss of braking when you run over a pot hole and rear end the car in front of you. Some have reported it on here, I'd stay away from gen 3s in this day and age.
    #25 Grit, Dec 8, 2019
    Tim Jones and AltraStache like this.
  6. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Don't do it......
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Good Idea..............!
  8. Dany Kong
    Dany Kong New Member
    Cambodia
    Can u gimme some tips? my prius car fob battey alway dead again and again after i change it new 10days?
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Are you buying economically priced batteries? I bought some of those and each button battery last no longer than 3 months. The more expensive ones last up to 2 years, got what i paid for.
  10. ChapmanF
    19,050
    Somehow I've experienced the quick switch-to-friction "whoopee!" hundreds of times in my Gen 3, just as I had in my Gen 1 before it, and my mom's Gen 2, but never in a Gen 4 because I haven't driven one, and on none of those occasions have I used it as an excuse to rear end the car in front of me. I suppose the only thing I've lacked has been motive.
  11. bisco
    52,888
    perhaps you lacked tailgating
    Grit and Mendel Leisk like this.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO:
