2011 Prius noise taking off
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Nov 10, 2022.
  1. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Is this the used transmission? They should give you at least a 30-60 day warranty...
  2. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Junkyard 90 day. It has been about 3 weeks I think.
    ASRDogman likes this.
  3. Raphael Muscarelle
    661
    222
    Really weird this is locked up. Maybe the oil pump didn't work?
  4. Raphael Muscarelle
    661
    222
    Interesting note. I found just about 0 metal in oil that came out. Really weird I say.
  5. ASRDogman
    8,067
    4,089
    I almost hate to ask, butttt, did you put the Toyota fluid in it???
  6. ASRDogman
    8,067
    4,089
    Well, take it back. It's a pain to do all that work, again.....
    Oh, did you check the clutch disc? Check the springs and make sure the are not broken.
  7. Raphael Muscarelle
    661
    222
    Disk looked good to me. I replaced it last time I rebuilt the engine.
    Looks fine but maybe I don't know what to look for. Springs are intact. I didn't have any pieces fall out taking it apart or nothing. Will look close tomorrow tho.
  8. Raphael Muscarelle
    661
    222
    Might want to share this. There seems to be 2 different exhaust systems for the 2011 Prius. Unknown why they used 2 different flanges on these but they did.
    The exhaust that has coolant going to it uses a dual plane donut gasket connecting the manifold to the catalytic converter.
    The other has a single plane.
    Using the single plane donut doesn't engage the catalytic converter flange enough to make a good seal.
    This seems to be my exhaust leak problem.
    I'll try to remember to take some photos of what happens if you use wrong donut.
    ASRDogman and Mendel Leisk like this.
  9. Mendel Leisk
    42,355
    The exhaust without coolant heat recovery was maybe sold in Europe, due to different reg's? Yeah, any time you have two different interface styles, you're asking for trouble.
  10. Raphael Muscarelle
    661
    222
    And yet I got a 3rd donut for this year of Prius. Obviously it is not for my exhaust.
    I'll have to post pictures it's really weird having 3 completely different donuts assigned to a single year of a vehicle.
  11. Raphael Muscarelle
    661
    222
    I actually ordered all variants of the donut so I've found 3 distinctive different types.
  12. Raphael Muscarelle
    661
    222
    This is original. It has a dent in it. I suppose that's the reason it leaked.
    Showing the profile. Notice there is 2 planes 1 on an angle one more straight up and down. IMG20221213144200.jpeg
  13. Raphael Muscarelle
    661
    222
    This is I believe not sure tho a felpro note it's one angle and flange marks are not very deep into the surface. Probably why it was leaking not engaging the flange well enough.
    So sad I usually like felpro
    #93 Raphael Muscarelle, Dec 13, 2022
  14. Raphael Muscarelle
    661
    222
    This is way too big it's a walker 31379
    I think it's for the non coolant exhaust system.
    ID is too small to go over the manifold. It's also much bigger in all the other ways.
    #94 Raphael Muscarelle, Dec 13, 2022
  15. Raphael Muscarelle
    661
    222
    This looks correct angles and size. Mahle 31662. Second pic has original along side. Can surely tell the flange engaged just about all of the angle plane. So bingo there is my exhaust leak problem.
    Now I just have to get a transmission and put it all back together. IMG20221213144334.jpeg IMG20221213144403.jpeg
  16. Raphael Muscarelle
    661
    222
    I have been wondering what did this to this transmission I keep on coming back to the oil pump I put 3,000 mi on this before it locked up If the oil pump didn't work I would think maybe 500 to a thousand miles. I could be very wrong since I have no experience with this particular type of transmission.
  17. Raphael Muscarelle
    661
    222
    Yes I did
  18. Raphael Muscarelle
    661
    222
    I just looked at four transmissions All of them were locked up the same way. Junk yards are not putting the caps on right away to block off to humid Florida air must be rusted.
    So no love yet.
    #98 Raphael Muscarelle, Dec 14, 2022
  19. Raphael Muscarelle
    661
    222
    Total of 7 transmissions I looked at today. 6 I couldn't turn the input shafts and one turned but had a hard spot in the rotation.
    None of them I trusted.
    All the ones that didn't turn were stored in humid Florida with no driveshaft caps on them. Is it possible they are frozen with rust.
    The one that turned was shrink wrapped but didn't trust the hard to turn spot.
    So nothing was bought today.
    I stopped at the dealer because my driver wanted to ask some questions and look around.
    For jokes I inquired about a new transmission. I didn't think it would be available. Oh but yes it is $3100.00 which I will be buying after I move some money around.
  20. ASRDogman
    8,067
    4,089
    Have you searched for a remanufactured transmission?
    Here are a few:
    https://reman-transmission.com/transmissions/toyota/prius/2011
    https://carpartplanet.com/transmissions/toyota/prius/2011
    https://www.ebay.com/b/Complete-Auto-Transmissions-for-Toyota-Prius/171115/bn_1494520?mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5337590774&customid=&toolid=10001
