2011 Prius noise taking off
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Nov 10, 2022.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I'm sure I would have noticed this either taking it out or putting it back in so it must have just collapsed.
    I'm Gonna get an OEM mount from the dealer.
    Done done and done.
    Btw similar but very different symptoms then what I had going on before.
    ASRDogman likes this.
  2. Raphael Muscarelle
    661
    222
    Im Starting to feel I should have a camera on my head as I do these things. So I can go back in time virtually.
    ASRDogman and Mendel Leisk like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    With some things, it's not worth going cheaper on.....
    Is that the only mount you replaced? How do the other ones look?
  4. Raphael Muscarelle
    661
    222
    These mounts I replaced when the vibrating started with the junkyard trans.
    I had them all out they all look new because they are.
    Everything was smooth when I test drove the vehicle.
    So yes that was new then about a month ago to try to fix the vibration then.
  5. Raphael Muscarelle
    661
    222
    Correction mounts were replaced to try to fix takeoff noise.
  6. Raphael Muscarelle
    661
    222
    I briefly went through the Prius books I have owner stuff. I was looking for when the first service to the transmission is I was kind of thinking the transmission fluid should be changed fairly quickly like thousand to 2000 miles because the brake in of the transmission probably put a quite a bit of metal into the fluid. I don't see that in the literature that I have.
    I'm sure changing it that time won't hurt.
  7. Mendel Leisk
    42,355
    I changed the transaxle fluid on ours several times. First time, at a mere 12 months and 15K kms, it was the darkest. Next time it was only modestly darker, at 40K kms. Next time, at 64K kms, it still looked like new, and I decided to quit, lol.
  8. Raphael Muscarelle
    661
    222
    Sorry put 300 miles out on This transmission I'm going to say this The white noise you get from the engine compartment while you're going down the road is a lot less
  9. Raphael Muscarelle
    661
    222
    When do we think the first change should be I kind of think 2000 miles
  10. Mendel Leisk
    42,355
    Yeah it seems like break-in period it gets dirty fast, then ok.
  11. Raphael Muscarelle
    661
    222
    I realize what killed my differential. It's actually what kills older Honda transmission. Not coming to a full stop going from forward to reverse.
    I didn't think it would be a big deal but apparently it is after several thousands of times.
  12. ASRDogman
    8,067
    4,089
    So I take it the NEW transmission is functioning well?
    And the car is back in service?
  13. Raphael Muscarelle
    661
    222
    Car is running great now. Just about 2k miles on the transmission so I'm gonna do fluid change. Not sure if it's necessary. But doing it anyway.
    I'm going to rotate the traction battery this week also.
  14. Raphael Muscarelle
    661
    222
    Mpg on dash is 50-52 no highway miles. so running fairly good.
  15. Scarlett Johnson
    Scarlett Johnson New Member
    2011 Prius Alpha
    You can buy Grade "A" Used Auto Parts Like Engines, Transmissions at Best Quality Auto Parts LLC
