2011 Prius Original Wiper Blade?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by darkgiant, Oct 14, 2018.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I am looking for the original wiper blades that come with the 2011 Prius... I saw some Denso ones on Amazon but wasn't sure if those were it. I am looking for those because I have tried just about every wiper and it seems like the suggestion of going with the original baldes and swaping out the blades is the best option and cheaper in the long-run.
    Also, where would be the best place to get these wipers for a cheap price?
  2. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Been looking for these myself for some time with no luck
    Mi MIX 2S ?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I would stop by the local Toyota dealer as they sell the refills and are usually competitively priced;).
  4. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Sorry I was actually looking for the actual wiper (not the refill)
  5. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    You could also see what they charge for the unit too:).
    Then see what other outlets charge(y).
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    In Toyota’s parts catalog for the 2011 Prius, Figure 85-01, Windshield Wiper, shows the part numbers:
    Blade, Front Wiper, Left: 85222-75011
    Blade, Front Wiper, Right: 85212-47040
    Rubber, Front Wiper, Left: 85214-68020
    Rubber, Front Wiper, Right: 85214-30390 ​
    You can start with a set of blades (list price $29.99 each), which include the rubber inserts, and then replace only the rubber inserts (list price $9.99 each) as needed.
    The replacement parts available today at Toyota dealers, including several with online stores, may or may not be identical to those originally installed at the factory, but if you buy from a dealer—not someone selling counterfeits under the same part numbers—they are as close to the originals as you’re likely to get.
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Typically get them on e-bay. Lots of dealers selling wipers and filters --- spark plugs. I get them from a dealer in CA -- Im on the east coast -- only takes couple days. no tax and free ship
    Bay Stater likes this.
  8. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Sorry for the late response here, but I found this on eBay with free shipping for $29.99 each ($60 together)... just out of curiosity, is that worth it? I ask because the most I've ever spent on a pair of wipers is literally $30 (Bosch Icon's and RainX brands), which makes me wonder if I should just try another pair of Bosch Icons or RainX again...
  9. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I called around dealers and a lot of them are asking for $80 for the two wipers (excluding tax!) That is bonkers for windshield wipers! I think I might just go ahead and try another pair of Bosch Icons...
  10. Mendel Leisk
    42,040
  11. jlim888
    jlim888 Member
    78
    36
    Thank you for the part numbers. I just ordered the above rubber wiper refills from FremontToyota.com for my 2011 Prius. It's $7.49 each. No shipping charges because I will do a Will Call, on my way to work:)
    Elektroingenieur likes this.
  12. jlim888
    jlim888 Member
    78
    36
    Hi Elektroingeniuer, again thank you very much for the front wiper part numbers, I just installed the refills, very easy :)
    I just noticed the rear wiper requires changing too. Can I trouble you to look up the part numbers?
  13. Elektroingenieur
    2,515
    3,287
    Three Touring
    parts.toyota.comHybrids & FCVPrius2011HybridHatchbackElectricalWiper & WasherRear Wiper:
    Blade Assembly, Rear Wiper: 85242-47030
    Rubber, Rear Wiper: 85214-0E050
    jlim888 likes this.
  14. jlim888
    jlim888 Member
    78
    36
    Hi Elektroingenieur,
    Thank you for the rear wiper part numbers. I bought the refill (85214-0E050) from FremontToyota.com for $7.49.
    See picture below. I accidentally broke the side tab of the blade assembly. I super-glued it back. Let's hope it would stay, if not, I'll just buy the Blade Assembly (85242-47030: $16.49).
  15. gsabsa
    gsabsa New Member
    Oregon
    My Southern Oregon toyota dealer says they can special order 2010 OEM wiper "bows". They carry the refill inserts in stock for $10.00. My OEM skippped and I did not like them. I use Costco Michelin at $10.00 (8.00 on sale). The are easier to install than replacing the inserts. The passenger side wiper is a bit past the edge of the windshield at rest, but works perfectly in the rain.
