2011 Prius Overheating issue coolant reservoir getting hot and red temp light turning on
Discussion in 'Gen 3 Prius Main Forum' started by Minh, Mar 12, 2023.
  1. Mendel Leisk
    41,355
    New engine, or what they refer to as new-to-me engine?
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    12,712
    5,137
    Pacific Northwest, USA
    I wonder if there was a mistake made when replacement engine was installed? One time a someone on here found a bolt clogging one of his coolant lines. How many miles of normal operation, if any, after engine was replaced?
  3. KamiKKazi
    KamiKKazi Member
    91
    58
    OC
    Since you don’t really know the history on the car I don’t know exactly what’s going on but I would make an educated guess that the previous engine/ engine coolant had head gasket sealer in the coolant based on the fact that the engine was replaced. They really only replace engines when the head gasket fails unless you drive the failed head gasket until the piston shoots out of the block. Then you definitely need a new engine. I would say replace the engine radiator first because how would the inverter coolant pump affect it unless you are getting specific codes for the inverter. This is what the head gasket sealer looks like in the coolant after being in the car for some time.
  4. PriusCamper
    12,712
    5,137
    I like what you're saying here... But what's still confusing is that when an inverter pump fails the warning lights don't come on just because the pump is not working, they come on after the invert recognizes that it's running too hot. And why would that error code not come up if the system is clearly running hot? Or maybe it is and I misunderstood?
  5. KamiKKazi
    KamiKKazi Member
    91
    58
    OC
    Yes I do not completely understand the inverter failure symptoms but I would check the inverter coolant pump to see if it circulates fluid in ready mode. I would not rule out the inverter pump until having someone look at it but a mechanic will do the work replacing it whether it is needed or not…Also read the codes if you can it would help.
    edit: just saw no codes in the OP
    #25 KamiKKazi, Mar 15, 2023
  6. PriusCamper
    12,712
    5,137
    I wonder if OP is not being clear enough about when warning lights/error codes happen? Because if your inverter coolant gets too hot the car is gonna throw a red triangle and as the situation gets worse the car will shut off the hybrid system entirely, which would be consistent with loss of power on freeway and coolant reservoir being hot? But as I read their description the inverter coolant is super hot and there's less power on the freeway but there's no dash lights / error codes. That doesn't make sense?
  7. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Engine speed for peak power, for peak torque, for peak engine efficiency, and for peak car mpg in some specific circumstances are 4 separate speeds. There's no reason to expect them to be identical.
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,107
    6,267
    Texas Hill Country
    First and foremost quit driving a gen3 that is overheating. A "new" engine either means a new to me used engine or a rebuilt used engine. Both could have counterfeit or otherwise bad water pumps.
    If you must continue driving at least get a monitor for coolant temps. I suspect you are driving at too high temps all the time but just break alarm thresholds on high speed hills.
    I continually monitor engine temp with a low cost (-$30) P10 scanner which allows user set alarms.
    I can quickly switch to a bluetooth obd2 scanner ($32) feeding the "Car Scanner" app which is also highly configurable.
    Since it is on your phone it is easy to record a drive and review later if desired.
    Brian1954 likes this.
  9. Minh
    Minh Junior Member
    22
    Sacramento
    Thank you in this chat forum. I was able to resolve my issue. My radiator was plugged up with oil residue from previous engine and some kind of coolant fix a leak composite. Really plastic gunk that was in my radiator so there was no kind of flow through. Plus now my heater works amazing. I will attach picture that I took. Hope this will help someone else who come across similar issues. Now the red temp light doesn’t turn on when going up hills over the Altamont pass. So relieved Now get new struts and shocks.
    KamiKKazi, Mendel Leisk and CR94 like this.
  10. ASRDogman
    ASRDogman Senior Member
    7,555
    3,900
    Stop leak should be called stop FLOW.... It's HORRIBLE crap and should NEVER
    be used unless you intend to replace coolant related parts.
    Also remember that the small coolant passages in the engine block get clogged also.
    Sometime in the near future you might want to also back flush your heater core with
    white vineager to unclog that also.
    And maybe cleaning off the coolant temp sensors...
    #30 ASRDogman, Mar 20, 2023
  11. Mendel Leisk
    41,355
    50/50 mix of white vinegar and water was recommended by one of the stop-leak manufacturers. There’s a link in my signature with some thoughts on how to do this.
  12. rjparker
    10,107
    6,267
    Texas Hill Country
    Pretty sure he bought the 2011 recently. He bought a 2005 back in 2018 so this one was probably a head gasket case temporarily repaired by a scammer using input from Priuschat. Its a problem and is the number one reason I try to discourage people considering a gen3.
