2011 Prius P0108 and p0328 p lock malfunction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Buske, May 14, 2020.
  1. Michael Buske
    Michael Buske New Member
    17
    Midwest
    Two Eco
    I earlier posted about a p lock malfunction but because of the coronavirus and my mothers surgery I ended up parking the car with the hope I would eventually find a scanner to figure it out. I bought a new battery and that did not work. So for a month took the battery off the cables and let it sit. I put the battery back on today and it ran. So I ran to the nearest mechanic and had it scanned. While driving the p lock malfunction note came on and it did not seem to want to go into park. Anyway I was able to get it scanned and the codes p0108 and p0328 came up as well as c2300 and c0293. He cleared the codes but I am a bit scared to turn the car off so I might be able to drive it to toyota to get a better scan. I may leave the car running all night for fear of it not going into drive again. Any insight would be much appreciated.
  2. Michael Buske
    17
    Midwest
    Two Eco
    Even though I did not turn off the car it again won't go into park or drive and says p lock malfunction. So I turned it off. I checked under the hood while on and there was a louder than usual buzzing noise
    52,819
    it's usually corrosion and moisture. you might have to flatbed it to a dealer
  4. Michael Buske
    17
    Midwest
    Two Eco
    So I took off battery cables and put them back on this morning and car ran again. If a rodent chewed on a cable would it more likely to work in warmer weather? And would you see the codes and p lock like I am seeing?
  5. bisco
    52,819
    not likely. might be the moisture drying up. is there inverter fluid movement when ready?
  6. Michael Buske
    17
    Midwest
    Two Eco
    When lid is off it looks like it is moving very very slowly. I listened for noise but there is a buzz sound around where the oil dip stick is that takes over.
  7. bisco
    52,819
    disconnecting the 12v resets the trouble codes and allows the car to drive until they set again.
  8. Michael Buske
    17
    Midwest
    Two Eco
    Yea did that a couple of times for over a day and it did not work. Actually had the battery off for near a month. The car ran then and then the check engine light came on. But codes were still there. I had the codes read and he said he cleared them but check engine light came on and actually the p lock error occurred this morning and I could not drive very briefly then it drove around and could put into park again. I am going to chance it tomorrow and drive 25 miles to nearest toyota dealer for a diagnostic.
  9. bisco
    52,819
    all the best!(y)
  10. Michael Buske
    17
    Midwest
    Two Eco
    So this was because of a mouse. Actually my first inclination if anybody read the original thread. Five wires needed to be repaired and has been running fine the whole week. Costs $200.00. I also think the warmer weather and humidity helped get a few of the wires to work so I did not have to tow it.
  11. bisco
    52,819
    mice. only good for lab experiments
