2011 Prius P0303 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rtstrider, May 15, 2017.
  1. Lithium MPG
    Lithium MPG Junior Member
    27
    27
    Inland Empire
    2013 Prius Plug-in
    Keep us updated!
  2. rtstrider
    rtstrider New Member
    24
    Southeast
    So far so good! Wife even said it hasn't driven this good since we've had the car. Fingers crossed from here on out!
  3. Psl2013
    Psl2013 New Member
    Psl
    how many miles and have u drained the coolant dont use water bleed out air
  4. rtstrider
    24
    Southeast
    It's been a little over 2 weeks of very heavy driving (over 1k miles) and still good. I'll call this issue fixed! It's driving better than it ever has since we've had it. All in all this was not too difficult of a job, just time consuming (took me about 3 1/2 hours of really taking my time). If you can replace the spark plugs in this car and clean out the egr pipe you are already pretty much there anyways. I cross threaded one of the fuel rail mounting bolts. The other is just fine and holds tension without issue. I'm going to use the red hi temp thread locker (this stuff
    not the red high strength one) on the good bolt so it'll stay in place permanently. Right now it's holding tension without issue but we have a 500 mile mountain trip coming up next weekend and I see this as cheap insurance. Once it cools off outside in the fall I'll look at getting a thread repair kit for the stripped bolt/hole so we have a permanent fix. No I have not changed the coolant yet. I'll have to look at the mileage but it's roughly around 160k. From what the carfax shows this was kept up at the dealer. Every fluid I've looked at so far looked brand spanking new.
  5. rtstrider
    24
    Southeast
    Scratch the hi temp thread locker idea. I'm back to the drawing board and will be fixing this weekend.
    Lithium MPG and Raytheeagle like this.
  6. rtstrider
    24
    Southeast
    And we got almost 5000 miles this time. P0303 is back...Going to pull the plug tonight and look to see if it's fouled. UGHHHHH
  7. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Do you have wet oil at the bottom of your throttle body? Are your plugs oily wet, top of pistons oily wet?? Your engine is knocking from blow-by, oil is pushed out of the crankcase and into the pcv valve->pcv hose->intake manifold from excessive engine pressure. Clean out your entire intake manifold and install an oil catch can. It is the only thing I can think of if you have a healthy head gasket. You mentioned you already cleaned your egr cooler, egr pipe, cleaned injectors and installed new spark plugs. I have oil catch cans on both of our prius' and they do not knock. Oil catch can thread
    Repair that stripped thread with a helicoil.
    Helicoil
    mjoo likes this.
  8. danlatu
    533
    1,367
    maryland
    Blow-by can create wet fowling = misfire = knocking. Increased compression is caused by too much fuel(rich), oil or coolant/water in the combustion chamber. These are known as solids, these solids are incompressible.
    mjoo and Robert Holt like this.
  9. rtstrider
    24
    Southeast
    Just checked the oil and bone dry at 5k miles. We used bulk 0w20 this time. I added a quart of 0w20 I had laying around and that didn't even put a dent in this. Going to try changing the oil with mobil 1 high mileage 0w20 and run some gumout through this. The engine got hot and probably coked up the plug I'm thinking.
  10. rtstrider
    24
    Southeast
    I pulled the plug and it looks nasty! I looked at the other plugs and they looked normal. Now the oil had maybe 3 quarts in there. Did a drain and filled it up with mobil1 HM. Used the cheapo fram filter at Walmart. Going to keep an eye on the oil level and color and may just do a few short oci's to clean things up in there. If I had to guess maybe there is a bad seal allowing oil to creep up to the bottom of the plug in the 3rd cylinder?
    mjoo and NutzAboutBolts like this.
  11. danlatu
    533
    1,367
    maryland
    Oil can come from the intake manifold and valve seals. Have you opened up your throttle body to see if there is any oil under the throttle body? Oil can come from the intake valve and cylinder walls. Did your oil light come on, running that low on oil is really bad for the motor, is your motor consuming any coolant? I would buy some restore. It will buy you some time. Shake the can hard for 2+ minutes and then pour in with your next oil change and drive it 50 miles +
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    You're going to have to remove the valve cover and replace the spark plug tube gaskets.
    #32 NutzAboutBolts, Aug 25, 2017
  13. rtstrider
    24
    Southeast
    Nutz the top half was dry and this only seemed to affect the electrode area of the plug. Would that point more to the valve stem seals?
  14. rtstrider
    24
    Southeast
    No coolant is being consumed. I'll check the throttle body this weekend. If it is indeed the valve stem seals that's out of my comfort zone and a job for the mechanic. The valve cover and spark plug tube gaskets I could do though
  15. rtstrider
    24
    Southeast
    Not sure how to edit. No oil light came on
  16. bisco
    52,912
    the oil light doesn't come on until it's empty.
  17. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Most likely it's the spark plug tube gasket because if it was the head gasket, you would see coolant and over heating issues with low coolant.
  18. danlatu
    533
    1,367
    maryland
    Spark plug tube seals hardly ever fail. Oil would leak on top of the spark plug, not in the engine. Running low on oil and not changing oil will destroy seals, rings and bearings.
    Valve seals fail at 200k+, weak seals can be cured by high mileage motor oils like valvoline high mileage or atp at 205 reseal.
    I had a main seal leaking on my ridgeline @ 110k and used atp reseal. I have 158k and has not leaked since. Check the reviews on this. Easier than replacing valve seals or spark plug seals.
    #38 danlatu, Aug 25, 2017
    Raytheeagle and NutzAboutBolts like this.
  19. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I'd do a piston soak. GM supposedly makes a good one. The reviews are very good and there are testimonials of improving compression.
    Amazon
    Pixel XL ?
    danlatu likes this.
  20. rtstrider
    24
    Southeast
    We are on mechanic number 3. The 2nd one kept the car for over two weeks and nada. We are picking up the car from this mechanic and taking it to one that has very good reviews. The 2nd was the family mechanic and looks like they just have more work than they can handle right now. That and seems like as soon as the word hybrid is mentioned around here the mechanics lock up. I'll keep everyone in the loop on this one and HOPEFULLY we at least will have a diagnosis this week. :)
