2011 Prius Plus Performance (S1 package)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Stohnghost, Oct 22, 2020.
  1. Stohnghost
    Stohnghost New Member
    North America
    Hello - new to the forum.
    Background:
    I have a 2011 Prius 4 with the Plus Performance package. It includes a body kit, lowering springs, a fatter rear swaybar, and forged wheels. The car spent a majority of its life up north and the salt has taken its toll on the suspension components. The dealer quoted almost $3k to replace it with the correct TRD bits, and almost $2k for a standard Prius suspension. With the standard suspension, there will be significant wheel gap given the car was intended to be lowered.
    My question:
    Quite a few companies make aftermarket coilover kits for the 2011 Prius, but as I recall, the dealer said there was something different with the Plus package that would need to be addressed if I used a regular Prius setup (other than the ride height difference). With the aftermarket being cheaper than TRD and standard Prius suspension, it's obviously the best option because I can keep the lowered stance and save money. I emailed BC suspension and they asked for the chassis code, which is ZVW30L.
    I say all of that to ask - does anyone know or think a BC or similar coilover will fit this car? The chassis code seems to suggest yes - but the dealer made a fuss about this suspension mating up with a standard Prius suspension, therefore I worry that an aftermarket kit intended for a standard Prius may not work here -- does anyone have the ground truth on this?
    Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Do searches on what people have already done on here to get a sense of it... But, because of nature of Prius, your options are limited..
  3. Stohnghost
    North America
    Yea that may be so. Maybe someone with a Plus Performance model who has done a suspension swap can chime in. The car is getting pretty old, so I think those modders have moved on..
